Lowering advice
#32
Thanks, Rydewitme - that's the same question I've had; I owned an '06 A6 3.2 and put Eibachs and Koni FSD's on it - loved the look and the handling, but I soon traded for an '07 A6 4.2 S-Line...just curious if/when the need/desire arises, doing the same spring/damper combo on the '07 will make any difference compared to it's current setup...
#33
The shocks are compressed all the time, so will be more prone to slow leakage. You detect a pogo-ing effect, which becomes worse over time as you lose the damping effects of a normal shock absorber.
#34
#36
#37
Believe that H&R drops the car 45 mm, but I can't confirm that.
My car has settled to abt 40 mm below stock, could be due to the FSDs.
#38
#39
I am thinking of the S-Line springs/FSD set-up now. Initially I wanted to do Eibach/FSD but now I have changed my mind and leaning more towards the S-Line springs/FSD set-up. Based on what I have read it seems to me that the S-Line/FSD gives you the best of both worlds (performance/confort) compared to aother set-ups. I believe that the S-Line drop is 25mm but I have also some conflicting information of a 35mm drop. Can some of confirm the the drop is 25mm and not 35mm? Thank you in advance.
#40
nemesisa6
08-02-2010 05:11 PM
brian 4.2
08-23-2001 01:51 PM
Alex C
02-06-2001 09:47 PM
