LT: Audi A6 C6 diesel fault codes
Hi,
I just bought my first car, Audi A6 C6. I also bought a vcds cable and found the following faults:
Is someone able to help me crack these codes and solve the issues?
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0010
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 71692 136 63941
VCID: 24475997E7DBF66FDD-8070
4 Faults Found:
005676 - Glowplug Control Module; Supply Voltage
P162C - 000 - Open Circuit on Load Side - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 17:07:44
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 18.0°C
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:49
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.20 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:55
Freeze Frame:
RPM: 903 /min
Torque: 113.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 24.5 %
Temperature: 12.6°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:55
Freeze Frame:
RPM: 903 /min
Torque: 113.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 24.5 %
Temperature: 12.6°C
Readiness: 0 0 0 0 0
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030249321
Coding: 0002326
Shop #: WSC 02325 758 00200
VCID: 1C376177DFABCEAF65-8048
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:28
Freeze Frame:
Temperature: 21.0°C
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
Component: Heizgeraet H08 0060
Revision: C Serial number: 09011480
Coding: 0000111
Shop #: WSC 02335 758 00200
VCID: 1B35626BDAA5C9976C-804E
1 Fault Found:
02251 - Heater Unit Locked
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 65
Mileage: 248728 km
Time Indication: 0
Date: 2019.10.18
Time: 16:00:04
Freeze Frame:
OFF
Temperature: 80.0°C
Temperature: 84.0°C
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01045442750000
Coding: 3285637
VCID: 326BAFCFAD2F68DF5F-8066
1 Fault Found:
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 12
Reset counter: 25
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 22:41:33
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000263477
Coding: 0001003
Shop #: WSC 02323 758 00200
VCID: 5EB32B7F89379CBFCB-800A
1 Fault Found:
01797 - Power Steering Hydraulic Pressure Valve (N119/N315)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 7
Reset counter: 67
Mileage: 248740 km
Time Indication: 0
Date: 2019.12.05
Time: 14:32:00
Freeze Frame:
Voltage: 13.600 V
Temperature: 28.0°C
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0001066
Shop #: WSC 02327 758 00200
VCID: 2E53BBBFB9174C3F3B-807A
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 27
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:23
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0001066
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:23
Coding: 0011372
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 17:07:44
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 18.0°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:49
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.20 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:55
Freeze Frame:
RPM: 903 /min
Torque: 113.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 24.5 %
Temperature: 12.6°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 12:00:55
Freeze Frame:
RPM: 903 /min
Torque: 113.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 24.5 %
Temperature: 12.6°C
Coding: 0002326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:28
Freeze Frame:
Temperature: 21.0°C
Coding: 0000111
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 65
Mileage: 248728 km
Time Indication: 0
Date: 2019.10.18
Time: 16:00:04
Freeze Frame:
OFF
Temperature: 80.0°C
Temperature: 84.0°C
Coding: 3285637
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 25
Mileage: 248727 km
Time Indication: 0
Date: 2007.03.02
Time: 22:41:33
Coding: 0001003
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 67
Mileage: 248740 km
Time Indication: 0
Date: 2019.12.05
Time: 14:32:00
Freeze Frame:
Voltage: 13.600 V
Temperature: 28.0°C
Coding: 0001066
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 27
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:23
Coding: 0001066
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 248742 km
Time Indication: 0
Date: 2019.12.05
Time: 14:04:23
Are you having a specific problem? Some of the dates on those faults are from long ago.
But generally, I just want to learn to identify and fix the problems with vcds so my car is a good start
And I also I want to make my car 100% working
I would check the lock/unlock settings in the MMI system to see if that makes any change.
Another reference here: https://forums.ross-tech.com/showthr...Door-rear-left
J. Patterson (12-07-2019)
I would save the log and clear all codes and see what returns. My dealership leaves them too and I understand that it gives the future tech’s some history but I like to see a clean scan. I store and clear at each 10000 mile service Most of your codes are from a long time ago.
TeddyRule
03-16-2018 09:14 PM
Khalid
01-08-2018 02:39 AM
