Lube points
Just finished my 65k service + extra. Does anyone know what needs to be lubed? I don't believe everything was done during 55k. I am mainly looking for moon roof, seats, doors, but also joints and bolts else where? Also, want to do a coolant flush. What is the quickest way to drain it and flush it? Thanks in in advance.
Lubricating Sunroof and other stuff
<HR style="BACKGROUND-COLOR: #fff; COLOR: #fff" SIZE=1>https://www.audiworld.com/forums/showthread.php?t=2824660
The quickest way to drain it is to remove the bottom hose.
Also a good tip is that if you have a leaf blower open up the top hose and blow into it to push more fluid out. You're not looking for high pressure to do this just volume--hence a leaf blower. It really works.
BTW-- I'm looking to do a drain and convert to Evans waterless coolant. here's a link to check out. http://www.evanscooling.com/
Open the drain plug, pull the lower rad hose lose and let it flow.
Just do a little tape or rag to make a good seal with the blower and entry point.
You should start a thread about it.
Awesome feedback. Thanks guys. Ordered the lube and will do the job this weekend.
As of coolant flush there is more to it than I though. To refill, I will need pressure pump. Here's what I was able to find in OnDemand5.
ThirdEye
04-26-2005 04:57 PM
nick n
10-08-2000 08:09 PM
