A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
misfire? cylinder 2 fuel fouled
Old 05-16-2018, 08:47 AM
moezila's Avatar
Default misfire? cylinder 2 fuel fouled
So i have a 2010 A6 3.2 with cylinder 2 always dumping fuel, or at least the plug is soaked. I have changed many coils and plugs. I also changed the injector. i have p219d, p0136, p2236. Also changed both oxygen sensors on bank 1. At my wits end. Any help will help.
Old 05-17-2018, 10:53 PM
mkv
mkv's Avatar
Have you checked compression on that cylinder?
Old 05-20-2018, 07:18 AM
Nurke's Avatar
Once you get your cylinder flooded, you need to dry it first. With flooded cylinder you can not get good/real compression. Brand new spark plug will not fire when soaked in fuel. O2 sensors are there just to tell you whats happening with fuel/air mixture up in the engine. too much air too much fuel or too little air or too little fuel...O2 will tell you.
Pull the fuel pump fuses out, crank the engine for some time, then put tablespoon of engine or trans oil into cyl then crank some more. Then check your compression or put the plug back in (cleaned one with the fuel fuse back in). If still dumping fuel, then your injector is stuck open. But if it is stuck open, then you would see/hear fuel being sprayed into cylinder with ignition on only..as the fuel prime would leak thru that injector, then you would need to change that injector.
Y888
12-17-2015 11:57 AM
sauer99
02-25-2011 03:01 PM
videoviking
06-14-2005 03:57 PM
s4nit loves BOX
17
01-14-2003 12:53 PM
saunders
12-26-2002 07:11 PM
Quick Reply: misfire? cylinder 2 fuel fouled
