MMI 2005 A6 problem
My 2005 A6 MMI starts up but will not accept the main button signal to begin function. The radio and other functions work for about 30 seconds then goes out completely. The electronic key function begain to fail a few days before the whole system fail started. It seems that there are lots of potential fixes can anyone help with specific solutions. Thank Audifile
Sounds like the same problems I was having which ultimately led to the car not starting at all. You need to get someone to scan your car and reset the faults. Chances are this will temporarily fix the no start issue.
Ok, this has now started to happenon my car. When i start the car the Radio comes on for 30s, i can not get it to switch over to any other function like nav or car. After 30 sec pass all the lights on the MMI flash and then the screen goes dark and no buttons work no sound from radio. I did the three button reset but no luck. Does anyone know where the fuse for the MMI controller is? I will try to reset the faults with Vag and see if this helps. Any one else have an idea?
hope you get it solved...
here is my VAg Scan
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 77
VIN: WAUDG74F25N068991 Mileage: 178200km/110728miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02335 785 00200
VCID: 2A50CDCBFC6F
1 Fault Found:
18975 - Low Pressure Fuel Sensor (G410): Intermittent
P2543 - 009 - Open or Short to Ground
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 40
Mileage: 170038 km
Time Indication: 0
Date: 2011.01.31
Time: 11:07:30
Freeze Frame:
RPM: 1312 /min
Mass Air / Rev.: 223.5 mg/str
Temperature: 94.5°C
Part Throttle
Pressure: 4.9 bar
Speed: 63.0 km/h
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0065172
Coding: 0001002
VCID: 295232C7F969
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 264839FBE877
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0130
Revision: 30040401 Serial number: 10600300083552
Coding: 0000011
Shop #: WSC 08256 444 66570
VCID: E3CEE0EF5BC5
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000077978
Coding: 0524326
VCID: DBBED80F63B5
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: E6C8F9FBA8F7
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 215
Reset counter: 205
Mileage: 172856 km
Time Indication: 0
Date: 2011.03.04
Time: 09:01:00
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D080JFT
Coding: 0013622
Shop #: WSC 08256 444 67494
VCID: 264839FBE877
Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90055042960003
Coding: 0002041
VCID: E6C8F9FBA8F7
Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H09 0460
Revision: 00300000 Serial number: 4I210JNA4
Coding: 0065203
Shop #: WSC 08256 444 54176
VCID: 1E38111BB027
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804A180321
Coding: 6CFE73CC1B3904
Shop #: WSC 08256 444 59217
VCID: 275634FFEF7D
2 Faults Found:
00384 - Optical Databus
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 177631 km
Time Indication: 0
Date: 2011.04.27
Time: 20:30:04
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 177228 km
Time Indication: 0
Date: 2011.04.22
Time: 12:04:39
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: E1C2EAE741D9
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: h0
Coding: 0035563
VCID: 295232C7F969
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001399920000
Coding: 0424125
VCID: 2C5CCBD3F69B
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000042520
Coding: 0001114
VCID: DEB8D11B70A7
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Coding: 0035563
VCID: 295232C7F969
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDBAD6177DA1
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 08255 444 178146
VCID: E9D2F2C7B9E9
Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Component: AFS-Modul rechtsH05 0010
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0400
Revision: 00000000 Serial number: 00000000073491
Shop #: WSC 25807 444 57975
VCID: 234E20EF9B45
Part No: 4F0 915 105 C
Component: von VA0 4410190823
Coding: 344630393135313035432056413034343130313930383233
Shop #: WSC 00000 384 00290
5 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 3
Reset counter: 206
Mileage: 175189 km
Time Indication: 0
Date: 2011.03.28
Time: 13:19:16
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:17
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:28
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:38
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:48
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: E9D2F2C7B9E9
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
VCID: E9D2F2C7B9E9
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Chassis Type: 4F0
VCID: 2A50CDCBFC6F
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 170038 km
Time Indication: 0
Date: 2011.01.31
Time: 11:07:30
Freeze Frame:
RPM: 1312 /min
Temperature: 94.5°C
Part Throttle
Pressure: 4.9 bar
Speed: 63.0 km/h
Coding: 0001002
VCID: 295232C7F969
Coding: 0020895
VCID: 264839FBE877
Coding: 0000011
VCID: E3CEE0EF5BC5
Cannot be reached
Coding: 0524326
VCID: DBBED80F63B5
Coding: 0013123
VCID: E6C8F9FBA8F7
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 205
Mileage: 172856 km
Time Indication: 0
Date: 2011.03.04
Time: 09:01:00
Cannot be reached
Cannot be reached
Coding: 0013622
VCID: 264839FBE877
Coding: 0002041
VCID: E6C8F9FBA8F7
Coding: 0065203
VCID: 1E38111BB027
VCID: 275634FFEF7D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 177631 km
Time Indication: 0
Date: 2011.04.27
Time: 20:30:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 177228 km
Time Indication: 0
Date: 2011.04.22
Time: 12:04:39
Coding: 0082946
VCID: E1C2EAE741D9
Cannot be reached
Coding: 0035563
VCID: 295232C7F969
Coding: 0424125
VCID: 2C5CCBD3F69B
Cannot be reached
Coding: 0001114
VCID: DEB8D11B70A7
Coding: 0035563
VCID: 295232C7F969
Revision: C63C0030
Coding: 0005022
VCID: DDBAD6177DA1
Coding: 0000016
VCID: E9D2F2C7B9E9
Address 56: Radio
Cannot be reached
VCID: 234E20EF9B45
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 206
Mileage: 175189 km
Time Indication: 0
Date: 2011.03.28
Time: 13:19:16
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:17
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:28
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:38
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 173718 km
Time Indication: 0
Date: 2011.03.15
Time: 18:29:48
Coding: 0035370
VCID: E9D2F2C7B9E9
Coding: 0035370
VCID: E9D2F2C7B9E9
Cannot be reached
you done any jobs including fiber optics?
my guess is something with Optical connectors..?
was thinking about this:
I didnt do any optic changes in a few years. I added Nav when i first got the car. Everything worked well for years. As my CPO expired I did get Audi to Replace the MMI head (2-3 months old) due to a button malfuction. This just happened this morning, am wondering if some moisture got into the unit since its a rainy day today.
Ya, i have to wait to saturday to check the connectors on the controller since it involves takeingout the center console. Just for sh*& and giggles, i did check all connectors on the radio amp nav units. However since all are affected i have assume its the controller. My hopes aren't high on the loose connector since it behaves exactly the same time after time. I start car, audio is heard from sirus radio then all lights blink and the MMI shuts down. I would understand if i went over a pot hole or something but it happens as the car is motionless in park.
