MMI woes - 'Gateway not available'
Got an intermittent fault. Anybody got any idea? The symtoms are: press the CAR button and all I see is 'Gateway not available'; steering wheel buttons don't work; clock in MMI freezes; a/c & seat heating setup don't appear on MMI; PDC grahic doesn't appear on MMI; radio/CD info doesn't appear on DIS; switch off & pull key out and the radio or whatever continues to play; probably more funny things as well. Each of the main functions work, i.e. radio/CD, nav, phone. When a nav voice instruction plays it kills radio/cd sound all together. Spoke with my normally helpful dealer but caught them in an unhelpful mood - book it in was all they said. Au secours!
2006 3.0 TDi S-Line, pretty well loaded
Sounds like you have a faulty "Data Bus On Board Diagnostic Interface" (phew) This is J533 and is the interface that moves data between the MOST (optical fibre) infotainment bus ie CD,Radio,Telephone,navigation,MMI display, and the other data buses in the vehicle CAN and LIN. This will be the "gateway" that it complains about. The CAN bus specifically drives the instrument cluster and just about every other part of the car, lights,seats,steering,engine management etc etc. The techie should be able to tell straight away when he plugs the diagnostic equipment into the diagnostic port in the car. The module by the way sits above the glove compartment.
The fact that the rest of the car and the other infotainment stuff works points to this.
Good luck
Good luck
Good luck
Good luck
ileventh
Q5/SQ5 MKI (8R) Discussion
33
04-15-2021 10:51 AM
bnl107
13
03-26-2002 07:44 AM
