Nav Install
#11
I did the Nav install on my car. You can find the kit on ebay or go the kufatec route (I went with ebay). basically you need the DVD player and the wiring harness. Putting the DVD into the slot in the truck is not hard. You then need to run the cable to the C-pillar which has a wire coming from the antenna on the roof (US models have the antenna and we don't need to drill a hole to install the antenna). The next step is find a power for the DVD player - this is done by running a wire to the other side of the trunk where the fusebox is located. The last part is to incorporate the Nav into the fiber optics system - this means disconnecting one cable and insert it into the nav and the output of the nav going into the original cable.
No coding was required after this for the nav to work; no going to dealer or making any changes using VAGCOM - I really like the audi nav - being built in and not having to deal with the tom-tom kinda devices with wires hanging all over (the other day I saw a bentley with a gps mounted with a suction cup - what a shame).
#12
Is there write up or any pics/diagrams to go by with the unit? Would you be able to PM the part number for the Nav Unit and the wiring harness? I hate using the hand held unit also.
Thank you
Thank you
#13
The package that I bought from ebay had instructions printed out - not sure I kept them after the install. Here is one set of instructions (though I not seeing him showing the power wiring)
http://www.audiforum.us/installation...-a6-avant.html
I think this should be the retrofit kit, but I'd confirm with the kufatec people before ordering. Wiring appears to be: http://www.kufatec.de/shop/product_i...---MMI-2G.html
#14
Thank you. so I have to do no drilling through the roof of the car do I? I have shark fin antenna now
#15
Great maybe with good instructions I may be bale to do this. Do you rememebr what you paid for the wiring and unit?
#17
#18
Its a blue'ish green cable midway on the c-pillar. On non-nav cars this cable is folded looking like it is going up (and not coming down from the roof). It is on the driver side c-pillar. You just need to snake the antenna cable from the DVD unit and connect to this end.
#20
Im really confuse but I will check them Thanks
