Navigation shows wrong location, please help.
#14
I would update to MMI included on CD p/n 4F0 906 961AB which does not require Nav version above 5. But if your dealer got you the newest nav, you should probably update MMI all the way using the procedure in pierre's sticky.
#15
I read somewhere on here a while back that driving in a tight circle for a while might solve the problem. Haven't had the problem though so haven't tested this solution
#16
Well I now have the version 10 disc in there from the dealer so at least my maps will be up to date once it gets fixed. It is going back in next wednesday and we will find out what the problem is. Hoping they will update the MMI while they are in there. My gut says it HAS to be something with the antenna. Place your bets now and we will find out who was right next week.
#20
Yeah, I still think it HAS to be the antenna, but I can't believe they didnt update the MMI when you had it in there last. That should have been their first step, IMO.
Good Luck!
Good Luck!
