When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
The following picture is from the elsawin manual, but I can find the part number to order a new seal. The car is a 2006 Audi A6 with 3.2l engine. This Photo is the front sealing flange to the crankshaft. I have oil leaking from the seal and I need to replace it. Any help in identify the right part number to order would be greatly appreciated.
the seal around crankshaft isn't sold separate..according to ETKA..
it comes as a whole kit with the housing..
part nr: 06E 103 153 E
cheers!/H
Awesome thanks for the help, has anyone changed this out before, if so what kind of job is it. I'm not a mechanic by any means but I can do most things. I've got the Elsawin manual but limited information on how to do it. I assume pull the belt off and then the pulley. I should be able to get to it then I hope. Maybe there is not much else to it. I guess I'll find out.
