Need Help installing sub
I installed a sub in my car a few weeks ago according to a tutorial i found on here, but my amp doesnt turn off. I guess the wire it told me to tap the remote wire into is a constant wire and not switched. So ive been trying to find another source to plug the remote wire in. I have tried two different fuses in the trunk fuse box, one was for MMI and one for cigarette lighter. But with both of these the amp still stayed on. Can anyone tell me why or suggest another way or different fuse to wire the remote wire up to.
Did you use my DIY? Did you use LOC?
Here is a thread on how to connect (works just fine for almost a year now)
http://audiforum.us/threads/aufterma...audi-a6.13513/
This one I wrote when building a custom box.
https://www.audiworld.com/forums/sho....php?t=2796650
The wire I described in thread becomes hot after you open the car and stays hot for approx. 2 mins. after you lock the car.
yes i used that exact tutorial, i found all the wires and conected everything just like you said, but the amp doesnt turn off. I know you've had it hooked up for a while so it must work somehow, but i feel like that wire is a constant on power wire to the amp but then theres a remote wire that tells it when to draw power and not. Mine never turned off i waited 5 minutes. It works fine if i drive the car every day, but if i leave it set for 3 days the battery is completely dead.
What year is your car? I would check may be wiring is slightly different for your year. Also, I assume your car already had Bose, as non-Bose wiring is different. Also, make sure your LOC is connected correctly. I did this a long time ago and don't temember everything but I will take a look today and tomorrow to see where and how mine is hooled up. I have to reinstall a new sub as I finally blew mine last week;(
I have mine working just fine. I use an Audiocontrol LC2 which has audio sensing to trigger the 12v. On mine i notice that the amp does not shut off until after i lock the car. I think the bose amp stays on until the car is locked. Have you checked to see if the amp turns off when the car is locked? You may need to wait up to 30 seconds after the car is locked.
What kind of LOC are you guys using that have power? mine is just a basic one that converts the speaker wire into RCA out cables for the amp. I don't have any power plugged into my LOC. I ran a line from pin 1 which you said was the 12v wire to the remote wire port on my amp. What did i hook up wrong. I get that you have a different LOC than me, but if that same wire in your car can tell your LOC to turn off which then turns the amp off, why shouldn't it also just be able to be directly hooked up to the amp?
