Need some info STAT!
Anyone running 20x9 inch wheels? Are you lowered? What ET? I have new 20x9 with 265/30s. They sent me ET 35, I just don't think it's going to work if I lower the car(H&R coilovers in the mail). The shop I got them from failed to ask me for an ET and just sent 35. They have ET 45 as well, currently are checking to see if they have any ET 45 so I can swap out. Worst case I can put a spacer on ET 45 if it touches suspension...right. The question:
Does anyone have any experience that can shed some light on my situation? Opinions? Commentary?
Looked at that. His stock wheels are ET 52 if I remember correctly. 20x9 ET 50 works fine, ET 40 is super tight in the back. If my measurements are close... ET 38 up front with a 9 inch rim will be tight too. Without stretch on the tires he'll be bending sheet metal. IMHO. My real curiousity is how the suspension sits after lowering. The suspension moves in an arc, so does it pull in a little as you lower it? How much, 2-3mm or more? Can I play with the camber to tuck without burning thru tires?
I would go with the et 45 if you can get them. If they sit to far in you can add spacers.
The et 35 will never fit especailly in a 9 Maybe if you ran a 235 tire or something but then your messing with the fact that this is such a heavy car. For safety reasons on the min you want 255s under there. And 255s with a extra high load rating.
Well... I went down to the shop today and we did some testing. Car on a body lift, 20s on the car, old steel wheel flat under the right front and left rear... lower car. Suspesion compresses fully on wheels with steelies under 'em. THEY"LL FIT! There will be some rolling of the front fender and a trim of the liner in the rear but they'll fit. And by the way it looks HOT! Now, if my coilovers would hurry up and get here... I'm getting impatient!
I dont understand the steelie part?
I also dont know how your clearing everything. You might want to actually put the wheels on and drive the car before getting to exicted.
This pic is my car with a 20x8.5 et 38. The car is on a hill so its 3/4 of a inch lower on flat ground. These rims have a 245 on them. So your 3mm pushed off the hub more. Then the rim is .5 wider. If you plan on running anything bigger than a 255 I think its going to rub. Who knows though try it out and please let us know.
![](http://i108.photobucket.com/albums/n39/RoughedgesMR/IMG_0224.jpg)
The coilovers will lower it a min of 1.2 inches. And I doubt this. I mean your really hanging on threads to put it that high. So if you compressed your stock suspension to be 1.2 inches lower than stock ride height, and it clears, you will be ok. I am sure there will be some massaging which, I also, know I have to do.
Just got word that my coilovers will be here tomorrow... this weekend will be busy. I need to charge to camera and buy some beer. I've done more than my share of static drops on VWs and Audis, any special notes for a coilover install?
When we were testing we compressed both front and rear just over 2.2in. At that level everything is tight (like virgin tight!) but will clear, with a little massage on the lip and fender liner. I think it'll sit on that fine line between bad *** and sheetmetal damage... we'll see.
