New to me 2011 a6 avant... What now?
What's up? First post with my new car. Had a a4 sedan, but a recent baby and my wife and me being 6 feet tall or more necessitated a new ride. Found a beautiful light silver 2011 a6 avant 3.0t, premium plus package, light grey interior. 53,000 miles.
Fits us great, tons of space. Little bit of oomph when I want it, and for my long commute it makes things more comfy.
I can't say I'm a crazy car guy. But what the heck, it'd be fun to get 30 more horses. I've heard mixed reviews from ecu upgrades and supercharger pulleys. I need reliability. Any ideas on what to do?
Suspension and wheels will be done in the next 6 months.
I got my Audi A6 in September and just did the 115K mile service. After I changed the engine air filter and cleaned the snow screen, and replaced the spark plugs, (all were due at 115K) the car felt like it had more power.
Since you might not know the service history, those were somewhat easy items to do. This thread details it all: https://www.audiworld.com/forums/a6-.../#post23839229
Also have you tried to use Sport mode in the transmission?
Bigger wheels will make performance of the car worst not better because bigger wheels increase mass of the wheels (a.k.a. unstrung mass). You can improve the performance by getting dedicated summer and winter tires.
Changing suspension likely will change the geometry and make your tires last less. Also if you put the lowering springs from sedan on the Avant likely you will end up with unreasonably low rear (since back of Avant is heavier). It will result at even worst tire wear, strain on the brake hoses and uncomfortable ride.
Here is what happened to the brake hose on my old Avant after i put shorter springs designed for sedan: Audi Picture by beep-beep | 1019648 | AudiWorld.com Failed brake hoses is not what you new family needs.
Make sure the driver's rear drain is intact, and/or replaced. If not you'll potentially be fixing an amplifier (which takes out the whole MMI) after the next significant moisture event. You should be good with a 2011MY, but double check your build date for the plastic water pump impeller. Carfax actually had mine as being replaced already, so that could be another resource.
Up to you as this seems to be a debated topic, but I did a trans fluid drain/fill + filter.
Suspension geometry, unless radically altered, should be remedied with a new alignment at a competent shop and won't wear tires any worse than stock (except for the spirited driving it might encourage). Not sure what happened to yours beep-beep.
A tune will let you get back the boost the supercharger is already capable of making, and the bottom end is clearly stout enough to handle it. Shrinking the pulley size spins the blower faster. I can't recall if that debate was ever settled about what speed was 'safe' to spin the blower itself. Also, unless you keep your foot out of it - more HP = more gas.
Sounds like you have a sister car to mine...enjoy!
ayap
12
03-03-2009 05:00 AM
