Noise from upper part of 3.2L engine
First, let me start by saying I originally thought this sound was due to timing chain guides and tensioners, the noise is awfully similar. Also, don’t tell me to perform a search because I’ve scoured numerous pages of search with no success.
My car is a 2005 Audi A6 3.2l Quattro, Automatic.
After checking cam deviation for potential timing chain slack, the deviation is well within spec ( +-4 ) , and issues begin to occur at +-7.
Sounds like the noise is coming from intake manifold area or upper front part of the engine.
The noise is usually guaranteed on cold start, but still happens after warm starts as well.
The clicking noise eventually goes away after a minute or two, especially after revving at 1700-2000 rpm.
I’m anxious to hear what the Audi World thinks of this unsolved noise.
My '06 3.2 has a similar cold start noise.
While it also has an occasional tensioner clatter, for less than a second on cold morning starts(separate issue), once started, for about a minute or so, I'll have a noisy tappet sound that goes away with warm up.
I'm writing it off to an aged hydraulic valve adjuster that, like the sporadic tensioner, leaks down &, eventually, pumps back up with oil flow.
Just my guess.
BTW: My VCDS block 93 readings are ok too, even with that occasional short time cold start tensioner clatter(for now!).
Just my guess.
das60 (09-11-2022)
Hi, what is it which makes you think it's not the upper chain tensioners, other than the block 93 reading of 4 you mentioned? Do you have a smartphone - why not record a "voice memo" sound clip of a cold start and post it up for opinions...
Hi, I have the same sound just develop on my 05 A6 C6 3.2, it seems to come from the front right top of bank not the rear of the engine as i was expecting if it were tensioners etc? In fact doing the old screw driver to the ear trick the chain/s sound as if they're running smooth as a smooth thing at the back of the bank.
das60 (09-11-2022)
As this is a late thread not sure if you resolved this. I don't see additional information. But I just bought a 108K mile 2006 Avant 3.2L with the same loud noise in the upper manifold area center.
It had some slight noise from the top of the engine when I bought it. It also had a few vacuum lines that were broken I fixed those and as soon as I did (with an oil change) the engine started more of this clacking sound also much louder from that upper intake manifold area. I figured it was the chain tensioners as well. However I just did a trial an error attempt by going backwards from where it was when I first got it.
I backed off the vacuum line on the front that connects to the upper intake manifold and the loud noise went away. So what does that vacuum line control? Also before I did all this I got compression readings from all cylinders bank1 passenger side 270 and bank2 170 driver side.
Thanks-JH
Thanks-JH
Thanks-JH
Thanks-JH
