A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
P0346 :: Camshaft position sensor
Old 03-26-2012, 03:34 PM
  #11
lozts's Avatar
FYI - I have the ESP/ABS lights on. The Parking Brake Malfunction light is on. The Centre Brake light is on (might need to be replaced). The MIL light is on and the car wont shift unless I let off the accelerator and I have a loss of acceleration.
Old 04-16-2012, 06:03 AM
  #12
lozts's Avatar
Originally Posted by lozts
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDBA9C827D59
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 38
Reset counter: 47
Mileage: 154312 km
Time Indication: 0
Date: 2012.03.04
Time: 14:39:17
Freeze Frame:
Voltage: 13.25 V
Count: 236
How do I "Check DTC Memory"?
Old 06-17-2012, 09:28 AM
  #13
lozts's Avatar
It turns out it was the camshaft position solenoid valve and it was an easy fix. It took me all of 10 minutes to do and cost me $98 because I bought it from the dealer just to later find it online for $68 shipped (link below). It's held in by 1 star screw. You should examine all four of the camshaft solenoid valves to see if any of them look noticibly damaged (mine was loose around the crimp) or have a mechanic look at them/scan your car to see if he can tell you which one to replace. Mine was in bank 2 on the drivers side on the back of the block. If you are getting the same code then it could be the same one.
Part Number: 06E 109 257 J
Can be purchased here:
http://www.ubtuning.com/?product=364
Good luck!
Old 06-17-2012, 09:33 AM
  #14
lozts's Avatar
FYI: The issue with the solenoid valve was causing the sensor to only get 5V instead of 12V which was causing it to throw the code.
Old 01-15-2015, 05:55 PM
  #15
!staudi35's Avatar
funny thing, mine JUST SHOWED UP NOW after getting every maintenance done. I cleared DTC codes and see if it comes back again.
lotz, can you possibly post a pic to see where these solenoids actually are? Thanks a bunch.
Old 01-15-2015, 06:19 PM
  #16
FL C6.5 Avant's Avatar
Did you check this post from a recent thread here in this forum?
https://www.audiworld.com/forums/a6-.../#post24643287
also, there are other posts (don't have bookmarked handy--maybe someone else does)...about the screen mesh in these getting horked up.
Old 03-15-2016, 04:52 PM
  #17
boldenwell's Avatar
Originally Posted by jujuC6
If you are getting diesel engine like sound at start and misfires, you most likely have a bad cam tensioner. I had similar symptoms and it ended up being the cam tesioner which is more common on earlier version of our cars.
I've just experienced this symptom yesterday with my 2006 A6 V6 3.2 FSI. The rough idle sound disappeared after a bit of throttling, but reappeared every time the engine started.
I managed to fix the issue by unplugging, cleaning and reconnecting the two cam tensioner sensors. There was actually a bit of oil/moisture on one of them. They are located adjacent to the spark plug coils. Their cables came from the same spark plug leads. Thankfully, the problem is solved. The fault code hasn't appeared again and the rough sound/misfire at the start has gone.
Old 08-16-2022, 08:08 AM
  #18
Hoonrah's Avatar
Default Hey
Originally Posted by va-parts
It's not a sensor problem, you're timing is off. Do you have rattle sound on cold start? misfires?
I hear rattling sound from cold start sometimes but no misfires. It runs really well. Do you think it's still timing off?
Old 08-16-2022, 12:56 PM
  #19
A6Gary's Avatar
If you are hearing rattling sound during a cold start-up, your upper timing tensioners are probably at their limits. Using VCDS or other OEM compatible scan tool, you should check the camshaft angle. If the sum of the exhaust and intake values exceed ~7-8 degrees on either bank (assuming you have the 3.2L V6 engine), then that is a clear sign that the tensioners need to be replaced.
Old 08-16-2022, 05:43 PM
  #20
Hoonrah's Avatar
Default Thanks
Ok thanks. Ill check that out but I did an engine rebuild. I replaced all the chains and tensioners and I did the timing job with the timing chain set tool. If the value exceeds I still need to replace the upper timing chain tensioner?
Quick Reply: P0346 :: Camshaft position sensor
