View Poll Results: P164B - Oil pressure switch Malfunction Upper limit exceeded. What can cause this?
Does the CDYB engine has one or two oil pressure sensors?
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-r.gif)
![](https://www.audiworld.com/forums/clear.gif)
0%
No idea
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5-r.gif)
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Hi guys.
I am new to this forum
recently I have purchased an audi a6 c6 3.0tdi quattro automatic.
car looked honest and the e gine was purring nicely.
no service history.
The price was decent for a lot of spec so took the bite.
after a few long drives and pushing it harder I've got the glowplug light flashing and the message " do not exceed 2500 rpm".
ond scanner came up with the fault code in the title.
Switch the ignition off, it goes away and it does it again once exceeding 3700 rpm in 4th gear.
Replaced the oil pressure switch, not sure I've got the right one.
Read few threads on the forum and after a big sevice, took the sump down and ive seen that the oil pump has been replaced with one Gates, but no pressure valve in the sump.
Any ideas?
Thanks
no service history.
Any ideas?
Thanks
I was intrigued enough with your problem that I looked into it (as you clearly have). Perhaps you did not come upon the following which sounds like a similar problem to yours: Ross-tech Link
Hi Jonsie
Thanks for looking into this.
I did come across that thread last week.
I did convinced my mechanic friend to have a look and looking at the schematics of the N428 valve, it seems that it is actually in the sumo but it is siting in the top ...silly mistake.
Once the sumo is back on will have a go at changing the valve from the top.
I hope that is the problem.
anyone else. Please feel free to share your thoughts and your experience.
Just an update for others which might have this problem.
I have changed the solenoid, N 428 valve situated in front of the engine below the accessory belt. Problem solved.
Thanks for the update.
gbmarc
A4 (B8 Platform) Discussion
18
06-07-2024 07:10 AM
Remington Treich
11
12-28-2022 06:10 PM
chop13
Q5/SQ5 MKI (8R) Discussion
09-30-2019 05:14 AM
