P2404 Check Engine Light
Hello everyone,
My car is 2006 Audi A6 Base-Line.
About a week ago, I had a check engine light on and went to the Autozone to scan the code.
The error code was P2404.
The funny thing is that it came on for couple days and automatically went off.
And, suddenly, it came on again last night.
It never happend past 5 years of driving this vehicle, but once, only once, I put the gas in the tank while the engine was running. I think this might the problem with the issue.
What is going on with my car?
Does anybody have a similar experience that I am having?
I'm out of warranty so I am scared to death to go to dealer.
SAE P2404 = VAG 18836, which is the following:
Evaporative Emissions System
Evaporative Emission (EVAP) Canister Purge Regulator Valve N80 , checking
Evaporative Emission (EVAP) canister system, checking for proper seal
Leak Detection Pump
Leak Detection Pump (LDP) V144 , checking
P2404 Leak detection pump check: Reed contact open. For additional information, refer to the Bosch Motronic MED 9.1 OBD System Strategy. Page 17. 0 25 counts Refer to DTC P2404 in the DTC table P2404.
P2404 Evaporative Emission System Leak Detection Pump Sense Range/Performance Check Leak Detection Pump (LDP) V144 . Refer to Leak Detection Pump, Checking . High signal voltage > 10.4 V LDP Commanded on EVAP purge valve, Closed LDP, Activated Altitude, 2600 m IAT, >4 ° C delta ambient pressure, 2.5 kPa IAT drop after engine start, 6 K Time after engine start, 2301200 Sec. intake manifold vacuum, >15 kPa ECT, 4115 ° C ECT at start, 435 ° C Number of diagnostic attempts, 5 Vehicle speed, >25 MPH Selected gear, Any drive 11 Seconds Once/DCY 2 DCY
Leak Detection Pump
Hello everyone,
ive had my purge valve replaced , unfortunately by the dealer. the part about 20 and labor came up to 500 . back then i had no vag com so i felt for it....
same symptoms, check en came back went away and came back....
That's a lot of money.. Do you own the same vehicle as I have? How much did it cost you total?
Depends if is a leak can be dangerous.. Check your car around check hoses. And everything remove the cover to check all the plastic hoses that break so easy is under the belt cover...
