Parking Brake Problem
So I noticed when I changed my rotors and pads, a squeal kind of like the rear parking brakes are being ridden on. This is real evident when I'm by a wall at low speeds. When it gets faster I don't hear it as much. But a low speeds say from 5-15mph I hear the rear brake pads riding the rotors. Is there any fix or vagcom calibration? I followed Ross-Tech procedure to the point, I did the function test and everything. Thanks guys.
CORRECTED: There shouldn't be any squeal if you changed both rotors and pads. There must be something else going on. Why brand of pads and rotors did you use?
Was there anything like that with your pads that you didn't fit ?
I put in the anti squeal on the proper areas where the calipers meet the back of the pads. It's weird because I ran the brake function test again and it kind of made it a little better but I still hear the pads sitting and rubbing when I don't hit the brakes.
