Passenger Front Door Not locking
I know there are a few TSBs on the locks but has anyone had this issue?
All doors lock with key fob except the passeneger front. The car does not chirp when armed. When I open the door the alarm sounds. I dont have my VAG cable at the moment so best way to troubleshoot would be...???
Was it really cold when this happened? Maybe the module has some moisture in it and it froze?
Otherwise it is most likely a failure of the Door lock module (1B in the ETKA pic) and has to be replaced as it is sealed and comes as one part.
What I would do is this:
Get the car scanned with VAG-COM
Remove the door panel and see if all harness connections are firmly in place
Call dealer and get the part number confirmed
Get new module and install it
Good Luck
Good Luck
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Control Module Part Number: 4F0 910 793 B HW: 4F0 959 792 B
Component and/or Version: TSG BF H11 0040
Software Coding: 0051947
Work Shop Code: WSC 02327 785 00200
VCID: 2952075C8045B956E3D-807C
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 94
Reset counter: 106
Mileage: 177139 km
Time Indication: 0
Date: 2013.07.30
Time: 00:03:29
Saturday,14,December,2013,11:20:46:48283
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 94
Reset counter: 106
Mileage: 177139 km
Time Indication: 0
Date: 2013.07.30
Time: 00:03:29
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 94
Reset counter: 106
Mileage: 177139 km
Time Indication: 0
Date: 2013.07.30
Time: 00:03:29
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 94
Reset counter: 106
Mileage: 177139 km
Time Indication: 0
Date: 2013.07.30
Time: 00:03:29
Call Audi parts counter and get the part number based on the VIN # as I am not sure which part # you need. Here is third part # I found but when you search this part it shows 2002 - 2004 MY. So just make sure you get it right.
hellonwheels33
32
04-16-2023 07:32 AM
Inyoury
A6 (C7 Platform) Discussion
13
09-08-2015 05:04 AM
ajg617
09-06-2015 07:23 AM
stormchaser1967
09-02-2015 09:02 AM
