Please sticky Kev's TSB's
#13
Here's a quick list i just did up.
Let me know if any of the links don't work or if i forgot some.
http://www.uberlame.com/a6_tsb/Audi%...TSB%20List.htm
-Glen
-Glen
http://wiki.audiworld.com/index.php/AudiWorld_Wiki
..it's the place for getting fast info when people do google searches on Audi's and I'm sure our Kris Hansen will more then appreciate your contributions and naturally helping Kevin get his material in one pile helps us all..I'm sure it'll grow.
#14
Good job!! I've have the following TSB's that I downloaded from erWIN's site - and I also have the Bentely Manual TSB's. Since these are for an '06 3.2 (and not the '05 4.2), there is a change that there might be additional information here. If you notice any of them missing in your collection, let me know and I will upload/send it.
Someone has previously posted this text file with TSB's - it works great if you are doing a search:
00 Electrical components malfunctioning after windows have been tinted (2017729/2)
00 Software Version Management (SVM), operating instructions (2011732/6)
00 VIN plates, Safety Certification labels, ordering procedures (2004300/5)
01 MIL on (DTC P310B and/or P129F) (2015106/5)
01 MIL on, gasoline quality (DTC P0300 or P030x, lean condition DTCs) (2014753/5)
01 MIL/EPC on (P0087, P0088, P310B) (2017475/2)
10 Engine replacement, checking for debris lodged in transferred assemblies (2018288/2)
15 Rattle/knocking noise from camshaft adjuster atengine start (2010294/5)
17 Engine oil, oil quality standard (2010046/4)
17 Engine oils that meet Audi oil qualitystandards 502 00 and 505 01 (2010043/7)
17 Oil consumption measurement (2018550/3)
20 Fuel tank removed from vehicle, neutralizing fuel (2011703/2)
27 Battery discharged on vehicles with Advanced Key (2019143/1)
27 Battery testing with 5051/5051B/5052 scan too, charging with Midtronics InCharge 940 (INC-940) charging station - A6 (2012225/4)
37 ATF pan leaks (2013002/3)
37 Ignition key cannot be removed when transmission is in park orcannot lock vehicle (2010094/7)
37 Noises when changing from 6th to 3rd gear (2018789/1)
37 Vehicle lacks power or will not move after stop (2003658/3)
40 Shock absorber leaks: assessment aid (2018194/2)
43 Air suspension operative (DTC 1577) (2018304/3)
43 Self-leveling compressor inoperative (2018765/3)
44 Audi Tire Pressure Monitoring Systems overview (2011983/2)
44 TPMS diagnosis A4 (B7), A6 (C6), & Audi Q7 (2016525/3)
44 Vehicle pulls to one side (C6) (2016507/2)
44 Wheel bolts require torque adjustment (2010334/3)
45 ESP light on (DTC "Please read engine control unit") (2018191/2)
46 Brake pulsation diagnostic guidelines (2010097/3)
46 Brakes make moaning or "muh" noise when accelerating from stop or turning at slow speeds (2016681/6)
46 Brakes squeal (2017130/4)
48 Easy Entry function of the power adjustable steering column intermittently doesn't work (2015819/3)
48 Electric steering column adjustment is inoperative (2017266/4)
51 Vehicle inspection, protection removal and detailing (2009967/6)
57 Central locking locks up when removing ignition key from ignition lock (2018737/2)
57 Noises from lower door hinge (2018319/2)
57 Personalized memory settings of the key are not available (2019958/1)
57 Remote control key inoperative (2017082/5)
60 Sunroof headliner does not tilt correctly when sunroof panel is vented (2016022/3)
60 Sunroof switch jams or freewheels (2013012/3)
64 Convenience close/open feature of the door windows does not work (2016535/2)
64 Individual doors sporadically cannot be unlocked with the remote key (2017774/2)
66 Power folding rearview mirror malfunction (2016043/2)
68 Noises from the center console (2017707/2)
69 Interior cleaning products on and around airbag units (2017717/2)
70 Hook for trunk lining handle out of position (2018538/2)
70 Noises in dashboard area (2017483/3)
74 Head restraint feed-through visible (2018257/2)
74 Interior fabrics, vinyls and plastics, cleaning tips (2001906/4)
74 Leather upholstery, cleaning tips (2004327/3)
80 Temperature different between front driver and passenger sides (2013883/5)
87 Cleaning of the air conditioning refrigerant circuit (2018162/2)
87 Unpleasant odor from heating and ventilation system (2010146/6)
90 Cigarette Lighter Does Not Work (2010353/3)
90 IP cluster - Driver information system briefly blank after engine start (2019391/1)
90 Instrument Cluster: Service Interval Programming (2005613/4)
91 "Navigation not available" displayed on MMI screen (2016037/4)
91 Audi Music Interface (AMI): Use of iPhone (2018131/2)
91 Audi Music Interface (AMI): iPod doesn't work, message "unit or cable type not supported" (2018592/3)
91 Bluetooth Phone preparation: LG VX8700 drops Bluetooth connection (2019227/1)
91 Bluetooth phone cannot make wireless connection to R36 (2013422/4)
91 CD playback problems with nonstandard CDs (2013159/3)
91 Front parking assist inoperable (2018189/2)
91 GeKo, Radio Code Retrieval Using VAS 5051 (2010366/3)
91 MMI Car Systems menu contains grayed-out "Windows" option (2019927/1)
91 MMI Display screen is white or flickers (2017685/3)
91 MMI High: Some functions unavailable after 07 - Display/control unit replacement or MMI Zug software update (2017424/2)
91 MMI cannot be operated via Multi steering wheel operation (2016132/3)
91 MMI: Sporadic cracking noises, audio dropouts or completely inoperative (2015528/5)
91 MOST Satellite Tuner - Repair Authorization (2019092/1)
91 Navigation DVD can't be ejected (2013790/5)
91 Navigation MMI High: various malfunctions (2016330/2)
91 No bass on rear fader (2016732/2)
91 Noises from front door speaker (2018181/2)
91 Parking aid warning sound without obstacle (2012272/3)
91 Phone preparation inoperative or MMI sporadically inoperative (2018588/3)
91 Phone volume lowers intermittently during call (2017028/2)
91 Phonebook entries can't be imported from cell phone (2012766/2)
91 Radio reception and playback problems (2018701/2)
91 Satellite Antenna Module, DO NOT Dismantle to ReuseHousing (2010202/4)
91 Satellite radio has prematurely deactivated (2017730/2)
91 Sound system: interference (2018187/2)
91 Voice dialog system doesn't work on vehicles with phone preparation (2013274/3)
92 Windshield wipers streak, smear or are noisy (2010212/8)
94 Automatic headlight switches on and off without reason (2016808/2)
94 Daytime running lights do not work (2017488/2)
94 Exterior lights, moisture accumulation (2012749/7)
94 Headlights vibrate (2015445/3)
94 License plate light cracked, broken, loose or missing (2018740/2)
96 Hand sensor for garage door opener cannot be adjusted to HomeLink system (2019260/1)
97 DTCs, sporadic - contact check (2013504/4)
97 Electrical failures or component malfunctions - Wire harness repairs (2014745/4)
RVU - Repairing telephone preparation (CQ / 91D8) (2018510/3)
#15
Excellent job Glen but don't forget to add a link at AudiWorld Wiki:
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
#16
I also have the pdf creater - the kind which is licensed so that it doesn't leave those 'www.smartpdfcreator.com' imprints on the pages. I can ftp you the files if you want.
MNblackS4
10-07-2005 02:39 PM
Sia Bani
17
08-06-2005 08:16 AM
Formula1r
08-07-2002 10:16 AM
