Is it possible to make DRL stay on while headlights are on?
Is it possible to make DRL stay on while headlights are on without splicing any wires? Maybe via VCDS?
0xxxxx?: Country
1 = Rest of World (RoW)
2 = Northern European Countries (Sweden/Finland/Norway/Denmark)
3 = USA
4 = Canada
So change from 0xxxxx3 to 0xxxxx1
You should be able to do this via coding to the Central Electronics module and change the car to RoW (Rest of World) mode to have the DRLs stay on when the headlights are on.
0xxxxx?: Country
3 = USA
4 = Canada
0xxxxx?: Country
3 = USA
4 = Canada
Since you've customized the lighting in the car, I'm not sure if be able to assist much. Good luck and let us know what fixes you find.
0xxxxx?: Country
3 = USA
4 = Canada
0xxxxx?: Country
3 = USA
4 = Canada
The C6 DRL strip you are referring to is the LED DRL on the post facelift C6s (09-11). I was referring to the standard DRL bulb. Although I'd assume the coding would work for both since, the circuit is defined as a DRL and should be able to be modified as such.
I see now. My headlight housing did not have any DRL strip, it only has the DRL bulb. I modified an aftermarket LED strip into my housing and wired it to the existing DRL bulb circuit so it would act as the new DRL. I tried the code the day that you mentioned this and it didn't work. I will try again soon to double check.
