A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Pulling Emergency brake while driving. I tried it and...
Old 07-17-2005, 07:56 PM
fe342185's Avatar
Default Pulling Emergency brake while driving. I tried it and...
It releases automatically if your moving. Does not even skid. Not sure what speed but I'm guessing that if your moving it automatically disengages. By the way I was only moving 15mph I think. I would assume it would happen at any speed. Just thought I would let everyone know.
Old 07-18-2005, 11:28 AM
TulsaTime's Avatar
Default I'm out of town, so can't quote the manual, but... if I recall somewhere below 9kph
the brake will engage fully. Above that speed, you have to lift up and hold the switch to slow the car using the emergency brake.
There is a caution regarding lack of antilock and all brakes engaging at the same rate, so rear lockup and skidding is likely at higher speeds.
Old 07-18-2005, 05:18 PM
Der Kimbo's Avatar
Default "There is a caution regarding lack of antilock and all brakes engaging at the same rate"
Pulling the parking brake switch at speed is the same as using the pedal in a panic stop.
Old 07-18-2005, 07:45 PM
TulsaTime's Avatar
Thanks for confirming, by the way what did you bust?
Old 07-19-2005, 02:06 AM
New Member
Canon Shooter's Avatar
Default Re: Pulling Emergency brake while driving. I tried it and...
In a manual gearbox, lifting the clutch when stationary will automatically disengage the emergency brake if your seat belt is on. So I'd guessed that the brake would not engage whilst the car was in motion.
Begs the question then, why call it an emergency brake if you can't use it in an emergency? Surely it is now just a parking brake...
jmiller31
Q5/SQ5 MKI (8R) Discussion
12-26-2011 04:34 PM
Tg912
S4 (B8 Platform) Discussion
08-15-2010 07:42 PM
mgd99
04-28-2009 04:19 AM
LONESTARS5
26
03-23-2008 11:26 PM
Quick Reply: Pulling Emergency brake while driving. I tried it and...
