Push button starting issues?
Anyone else have issues with the push button starting feature? 3 times in the past 2 days the car would not start with the advance key. Even with the key in the inition it wouldn't start once and I had to shift to N and then back to P and then it would start with the key.
This is on an 08 3.2 by the way.
Chuck
Chuck
once i replaced the battery it worked fine... battery is $3 at any local store and it takes all of 10 secoonds to replace. Battery type is 2032.
Although i would first check the start function with your spare key to see if you have the same problem. I found that both my keys had battery issues but this was after 12 months of not once using the old fashion way to start the car![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
link below to instructions on how to replace battery -- if it takes you more than 20 seconds you're doing it wrong
<ul><li><a href="https://forums.audiworld.com/c6a6/msgs/38958.phtml">https://forums.audiworld.com/c6a6/msgs/38958.phtml</a</li></ul>
Crsutton21
A6 (C7 Platform) Discussion
09-26-2018 02:56 PM
agp2572
A4 (B9 Platform) Discussion
04-27-2018 12:12 PM
Brady Miklos
10-03-2016 06:52 PM
Trebax
01-22-2013 10:02 AM
