A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Question about Tire Pressure Monitor
Old 02-03-2010, 05:52 PM
mbpc4's Avatar
Default Question about Tire Pressure Monitor
Hi, I have a 2010 A6 and I have a question about the Tire Pressure Monitoring function on the MMI. Does the system give you a read out of the current tire pressure or it only warns you when tire pressure drop below a certain PSI? I store the correct pressure in the MMI but everytime I go the to Tire Pressure Monitoring menu, it asks me if I want to store the current tire pressure? Does this sounds right? Thank you.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/iPSfVqpCnkI3v77p8dKOxQ?feat=embedwebsite"><img src="http://lh3.ggpht.com/_6ACwqzyos5k/S1E8-zlaLQI/AAAAAAAABsM/CIbIBUsek50/s800/DSC_1175.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/PuzOed/Audi?feat=embedwebsite">Audi</a></td></tr></table>
Old 02-03-2010, 05:59 PM
zzz4's Avatar
The MMI will not show the actual tire pressure numbers. When it falls below a threshold (or malfunctions) the light will come on and it will beep. It will also illuminate the MIL light.
Old 02-03-2010, 09:03 PM
mbpc4's Avatar
Thanks for the info!
Jeff
Old 02-04-2010, 01:34 PM
hrc4u's Avatar
??... my shows actual pressure..(atleast i don't have static values shown?)
cheers!/H
Old 02-04-2010, 05:39 PM
zzz4's Avatar
How do you navigate to the pressure? I've never seen it on mine and I don't think it was in the user manual.
Old 02-04-2010, 06:49 PM
SupraLx570's Avatar
I have a 2010 3.0t and does not give u a read out. You set the tire pressure and it will ask you wether the pressure is as specified by manual, if it is you set it to that and then if there is loss it will go off and warn u.
Old 02-05-2010, 02:38 AM
hrc4u's Avatar
i have "display tire pressure" in the same menu as where i store or initialize tire pressure...? btw it also shows tire temperatures also
perhaps it's different on "older" cars as my -05
looks like this on my:
Old 02-05-2010, 05:07 AM
2008A6's Avatar
Interesting..never seen that. Are you in the USA?
Old 02-05-2010, 05:37 AM
hrc4u's Avatar
no im in Sweden
Old 02-05-2010, 06:29 AM
The G Man's Avatar
hrc4u, your tire pressure is all over the place, you need to adjust them
Quick Reply: Question about Tire Pressure Monitor
