question on battery drain in 2005 A6 3.2
I have like 4.5 amp parasitic draw, causing my battery drain in like 2 days. It is a new AGM battery which has been tested and is a good battery.
I have turned off the dome light, so when I open the door to pull fuses out, it does not turn on something, as I want what is staying on. Same thing, actually my trunk light is burnt out. I could not locate the one and off switch on the door and trunk where I can depress it, so that light does not come on anywhere?
I ran the VAGCOM and ran diagnosis, but quite don't know, if there is a way for
it to tell me what is staying on.
I see that there three fuse box locations, driver, passenger side on either side of the dash and then one in the trunk.
Has anyone had this problem? or what is more likely drawing that heavy draw
in A6?
Any help would be appreciated.
in A6?
jimmyjames72
02-08-2014 04:48 PM
tullheinz
9
03-26-2011 11:42 AM
