R8 V10 and S6 V10 motor differences
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 9"><meta name="Originator" content="Microsoft Word 9"><link rel="File-List" href="file:///C:/DOCUME%7E1/Paul/LOCALS%7E1/Temp/msoclip1/01/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} h1 {mso-style-next:Normal; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; page-break-after:avoid; mso-outline-level:1; font-size:12.0pt; font-family:"Times New Roman"; mso-font-kerning:0pt;} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {colorurple; text-decoration:underline; text-underline:single;} span.extref {mso-style-name:extref;} span.bullet-wingdings {mso-style-name:bullet-wingdings;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> Okay, so I've been doing research on what is the difference between these engines, and this is what I have so far. I need help from someone with access to etka or other audi parts catalog.
CHANGES BETWEEN R8 V10 and S6 V10
<!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
+90 HP on R8
+ 1500 RPM on R8
<!--[if !supportEmptyParas]--> -8 ft/lbs torque.
Change #`
<table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> R8 top fuel pressure 125 Bar
</td> </tr> <tr> <td style="padding: 0.75pt;"> S6 top fuel pressure 120 Bar
</td> </tr> <tr> <td style="padding: 0.75pt;"> <!--[if !supportEmptyParas]-->
Another 5 bar, ok this makes sense, higher fuel pressure, more fuel, needed for the much higher RPM, but seems minuscule, less than 4.5%.
Can someone tell me if the injectors are different part #s between 2 engines. Anyone know flow rates?
</td> </tr> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
S6 Valve stem diameter .015mm larger on intake valve, .010mm larger on exhaust valve than R8.
I don't think stem diameter affects flow or power, it's valve heads. Correct me if I'm wrong guys.
I wonder about materials, since the R8 revs harder, it puts stress on valve train. Are titanium valves used on R8? How about S6?
Crankshaft is definitely diff. on 2 cars, to allow higher rpms.
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> </tbody></table> R8 Crankshaft bearing journal 2mm larger (connecting rod journal diameter identical)
Pistons, bore, stroke, identical dimensions, material match must be confirmed **
+90 HP on R8
+ 1500 RPM on R8
Change #`
Crankshaft
bearing journal diameter
mm
mm
Crankshaft
mm
mm
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 9"><meta name="Originator" content="Microsoft Word 9"><link rel="File-List" href="file:///C:/DOCUME%7E1/Paul/LOCALS%7E1/Temp/msoclip1/01/clip_filelist.xml"><link rel="Edit-Time-Data" href="file:///C:/DOCUME%7E1/Paul/LOCALS%7E1/Temp/msoclip1/01/clip_editdata.mso"><!--[if !mso]> <style> v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} </style> <![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} h1 {mso-style-next:Normal; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; page-break-after:avoid; mso-outline-level:1; font-size:12.0pt; font-family:"Times New Roman"; mso-font-kerning:0pt;} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {colorurple; text-decoration:underline; text-underline:single;} span.extref {mso-style-name:extref;} span.bullet-wingdings {mso-style-name:bullet-wingdings;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> R8 ENGINE<o></o>
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Idle speed (not adjustable)
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Ignition timing
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Ignition/Glow Plug System
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> Spark plugs
</td> <td style="padding: 0in;" valign="top"> Names
</td> <td style="padding: 0in;" valign="top"> Tightening Specifications
</td> <td style="padding: 0in;" valign="top"> <form> </form> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Ignition sequence
</td> <td style="padding: 0in;" valign="top"> </td> </tr> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
G246 MAF SENSOR R8
<table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> <!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1031" type="#_x0000_t75" alt="A15-0326" style='width:24pt;height:24pt'/><![endif]--><!--[if !vml]-->[IMG]file:///C:/DOCUME%7E1/Paul/LOCALS%7E1/Temp/msoclip1/01/clip_image001.gif[/IMG]<!--[endif]-->VALVES S6<o></o>
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td colspan="2" style="padding: 0in;" valign="top"> Dimension
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> Dia. a
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> Dia. b
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> c
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> α
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
VALVES R8
<!--[if gte vml 1]><v:shape id="_x0000_i1032" type="#_x0000_t75" style='width:274.5pt;height:219.75pt'> <v:imagedata src="file:///C:/DOCUME~1/Paul/LOCALS~1/Temp/msoclip1/01/clip_image002.png" o:title="untitled"/> </v:shape><![endif]--><!--[if !vml]-->[IMG]file:///C:/DOCUME%7E1/Paul/LOCALS%7E1/Temp/msoclip1/01/clip_image003.jpg[/IMG]<!--[endif]-->
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td colspan="4" style="padding: 0in;" valign="top"> Dimension
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Ø a
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> Ø b
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> c
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="padding: 0in;" valign="top"> α
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="border: medium none ; padding: 0.75pt;"> R8 Technical Data<o></o>
</td> </tr> <!--[if !supportMisalignedColumns]--> <tr height="0"> <td style="border: medium none ;" width="18"></td> <td style="border: medium none ;" width="66"></td> <td style="border: medium none ;" width="66"></td> <td style="border: medium none ;" width="18"></td> <td style="border: medium none ;" width="91"></td> <td style="border: medium none ;" width="92"></td> </tr> <!--[endif]--> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td colspan="4" style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="3" style="padding: 0in;" valign="top"> Idle speed cannot be adjusted, it is regulated by idle stabilization.
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="3" style="padding: 0in;" valign="top"> Engine speed limitation via fuel injector shut-off
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="3" style="padding: 0in;" valign="top"> Fuel pressure
</td> <td style="padding: 0in;" valign="top"> Fuel supply-pressure up to high-pressure pump, (is produced by an electric fuel pump in the fuel tank)
</td> <td style="padding: 0in;" valign="top"> Fuel high pressure (produced by a mechanical single-piston pump) at approximately 85 degree coolant temperature
</td> <td style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: medium none ; padding: 0.75pt;"> Test Data
</td> </tr> <!--[if !supportMisalignedColumns]--> <tr height="0"> <td style="border: medium none ;" width="0"></td> <td style="border: medium none ;" width="164"></td> <td style="border: medium none ;" width="0"></td> <td style="border: medium none ;" width="248"></td> <td style="border: medium none ;" width="166"></td> </tr> <!--[endif]--> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt; width: 10%;" width="10%"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td style="padding: 0.75pt; width: 90%;" width="90%"> <table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> S6
</td> <td style="padding: 0in;">
<table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> Technical Data
<table style="border: 0.75pt outset ;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Engine data
</td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Idle speed (not adjustable)
</td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Fuel pressure after high-pressure pump
</td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Fuel pressure before high-pressure pump
</td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="border: 0.75pt inset ; padding: 0in;" valign="top"> <table style="border: medium none ;" border="1" cellpadding="0"> <tbody><tr> <td style="border: medium none ; padding: 0.75pt;"> l
</td> <td style="border: medium none ; padding: 0.75pt;"> <sup>1)</sup> Depending on engine control module (ECM) requirements.
</td> </tr> </tbody></table> <o></o>
<table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td colspan="3" style="padding: 0in;"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> </tr> <tr> <td style="padding: 0in;"> <table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> R8 Crankshaft Dimensions
</td> </tr> <!--[if !supportMisalignedColumns]--> <tr height="0"> <td style="border: medium none ;" width="515"></td> <td style="border: medium none ;" width="16"></td> <td style="border: medium none ;" width="16"></td> <td style="border: medium none ;" width="16"></td> <td style="border: medium none ;" width="16"></td> </tr> <!--[endif]--> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="" border="1" cellpadding="0" cellspacing="0"> <tbody><tr> <td style="padding: 0in;" valign="top"> Honing dimension
</td> <td colspan="2" style="padding: 0in;" valign="top"> </td> <td colspan="2" style="padding: 0in;" valign="top"> </td> </tr> <tr> <td style="padding: 0in;" valign="top"> Basic dimension
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> – 0.022
– 0.042
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> – 0.024
– 0.040
</td> </tr> <tr> <td style="padding: 0in;" valign="top"> Repair stage
– 0.042
– 0.040
</td> </tr> <tr> <td style="padding: 0in;" valign="top"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="border: medium none ;" border="1" cellpadding="0"> <tbody><tr> <td style="border: medium none ; padding: 0.75pt; width: 10%;" width="10%"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td style="border: medium none ; padding: 0.75pt; width: 90%;" width="90%"> <table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> <table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> S6 Crankshaft Dimensions
<table style="border: 0.75pt outset ;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Honing dimension
</td> <td colspan="2" style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> <td colspan="2" style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Basic dimension
</td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> – 0.022
– 0.042
– 0.042
</td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> Repair stage
– 0.042
– 0.042
</td> <td style="padding: 0in;" valign="top"> </td> <td style="padding: 0in;" valign="top"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
<table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td colspan="2" style="padding: 0in;"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td colspan="2" style="padding: 0in;">
</td> </tr> <tr> <td style="padding: 0.75pt; width: 9.96%;" width="9%"> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td colspan="3" style="padding: 0.75pt; width: 89.68%;" width="89%"> <table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> <table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> R8Piston and Cylinder Dimensions
<table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> R8 Matching pistons are allocated to the different manufacturing stages of the cylinder block.
<table style="border: 0.75pt outset ;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> <td style="border: 0.75pt inset ; padding: 0in;" valign="top"> </td> </tr> <tr> <td colspan="2" style="border: 0.75pt inset ; padding: 0in;" valign="top"> <table style="border: medium none ;" border="1" cellpadding="0"> <tbody><tr> <td style="border: medium none ; padding: 0.75pt;"> l
</td> <td style="border: medium none ; padding: 0.75pt;"> <sup>1)</sup> Measurement with coating (thickness = 0.01 mm). The coating wears off.
</td> </tr> <!--[if !supportMisalignedColumns]--> <tr height="0"> <td style="border: medium none ;" width="57"></td> <td style="border: medium none ;" width="4"></td> <td style="border: medium none ;" width="342"></td> <td style="border: medium none ;" width="171"></td> <td style="border: medium none ;" width="3"></td> </tr> <!--[endif]--> </tbody></table> <!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
</td> <td style="padding: 0.75pt; width: 90%;" width="90%"> <table style="width: 100%;" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td style="padding: 0in;"> <table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> S6 Piston and Cylinder Dimensions
<table style="" border="0" cellpadding="0"> <tbody><tr> <td style="padding: 0.75pt;"> Matching pistons are allocated to the different manufacturing stages of the cylinder block.
Engine data
5.2L / 4V / 389 kW-Motor
Not adjustable, regulated by the control module
Single coil ignition system with 10 ignition coils (output stages integrated) that are connected directly to spark plugs via the ignition cables.
→ Data sheets for exhaust emission test
<input name="InfomediaType" value="MM" type="hidden"><input name="titleId" value="420" type="hidden"><input name="titleName" value="Service Procedures" type="hidden"><o></o>
1-6-5-10-2-7-3-8-4-9
G246 MAF SENSOR R8
Intake valve
Exhaust valve
mm
33.85 ± 0.10
28.0 ± 0.1
mm
5.980 ± 0.007
5.965 ± 0.007
mm
103.97 ± 0.20
101.87 ± 0.20
45
45
VALVES R8
Intake valve
Exhaust valve
mm
33,85 ± 0,10
28,0 ± 0,1
mm
5,965 ± 0,005
5,955 ± 0,007
mm
103,97 ± 0,20
101,87 ± 0,20
45
45
Engine data
640 to 840 RPM
8500 RPM
3.0 to 6.0 bar pressure
between 20 and 40 bar pressure at idle
to approximately 125 bar pressure at certain operating points
5.2L / 320 kW-Motor
Approximately 650 RPM <sup>1)</sup>
18 to 120 bar pressure
Approximately 6 bar
Engine data
Crankshaft
mm
mm
Crankshaft
mm
mm
67.000
– 0.042
54.000
– 0.040
66.750
– 0.042
53.750
– 0.040
Crankshaft bearing journal diameter
mm
mm
Connecting rod journal diameter
mm
mm
65.000
– 0.042
54.000
– 0.042
64.750
– 0.042
53.750
– 0.042
Cylinder bore diameter mm
Piston diameter mm
84.510 ± 0.005
84.490 <sup>1)</sup>
84.610 ± 0.005
84.590 <sup>1)</sup>
Piston diameter mm
84.510 ± 0.005
84.610 ± 0.005
Pistons, rings, rods, bearings all the same....
crankshaft, different, maybe valve materials, and camshaft materials...
Still checking on injectors....
Primarily the way they get more power is revving the motor higher, and ensuring that there is enough air and fuel for increased rpm, and a couple parts that have increased load on high rpm can take it....
No need to rev that high if using a supercharger.....
all-go no-show
Audi R8
09-27-2006 03:29 PM
