Radiator Removal-Bentley
I need to pull yje radiator to get the bolts back in the crankshaft pulley. Can someone post the instructions on the removing the radiator? Thanks.
Why do you need access to the crank shaft pulley?
If your a DYIer you should buy a Bentley
You dont remove the radiator, you slide the carrier to the service position, the radiator is part of the carrier
Lock Carrier Service PositionSpecial tools, testers and auxiliary items required
Service position front end 3369
Removing
Loosen quick release screws - 1 - and - 2 - and remove noise insulation.
Remove left and right front wheel housings Wheel Housing Liner
Remove front bumper.
Remove left and right headlights Electrical Equipment - Repair Group 94 .
Unscrew bolts on lower left and right lock carrier.
Remove hood seal on both fenders.
Unscrew 2 screws - arrow - on upper left and right lock carrier.
Turn special tool for Service Position Front End 3369 left and right in holes for lock carrier screws to unscrew the respective screws.
Unthread remaining bolts - arrows - at left and right.
Push lock carrier forward carefully.
Installing
Installation is reverse of removal, noting the following:
Install lock carrier with attachments.
Allow torque arm stop to make contact with rubber buffer with own weight and tighten bolts - arrow - .
Install headlights Electrical Equipment - Repair Group 94 .
Install front bumper.
Check headlight adjustment Repair Manual, Maintenance .
Tightening torque
Removing
Installing
Tightening torque
Removing
Installing
Tightening torque
Removing
Installing
Tightening torque
No worries I completely forgot we can download from Bentley online. For anyone that needs to put the car in the service position there is no need for the tool (bolts). Just unscrew the bolts from the bumper and you can use them as the tool. They are the same size diamater and long enough. Works perfect.
![Name: 1387123258_zpsb0077b33.jpg
Size: 120.2 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/83223d1501529304-radiator-removal-bentley-1387123258_zpsb0077b33.jpg)
Pulley off, new bolts and belt going in today.
![Name: 1387123322_zps03649cde.jpg
Size: 86.4 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/83224d1501529304-radiator-removal-bentley-1387123322_zps03649cde.jpg)
uble1234
14
10-23-2020 08:07 PM
