Last edit by: IB Advertising
- Audi A6 C6 How to Replace Brake Pads Calipers Rotors<br>Step by step instructions for do-it-yourself repairs.
Rear brake pad change
#21
Long time lurker, first time poster.
I did the rear brakes on my 2005 A6 this weekend. I did not buy the Vag-com tool as I really have no desire to change any settings or anything. Also, I do not have a laptop, so moving my home PC into the garage to change my f'in brakes really did not appeal to me. Plus, the vag-com was just too much coin $275 for the cheapest version.
Rather, I simply bought the tool from Mactools.com, part No. EPB101. It is about 1/3 the cost of the vag-com but is limited to brake jobs.
Also, I pretty much figured out that you can get the piston to withdraw without needing the Mactool or the vagcom. You can remove the motor from the caliper using a torx socket to remove the two bolts. Once removed, inserting the torx socket into the back of the caliper and turning clockwise will with allow you to compress the piston. You can see this proceedure in the Bently manual as it is what they tell you to do when rebuilding the piston seals...... see funny story below for the reason why I had to rebuild the caliper....
Now, since I had the resetting tool in hand, I can not tell what my little proceedure will do, after installing the new rotors/pads. Namely, I do not know if it the computer will recalibrate the motor to the new spacing and reset the error code. I suspect it will. However, if it does not, you should be able to hit the local autozone and have them reset the codes for you.... Also, I had the tool in had from mactools the day after I ordered it, I did not even pay for the fedex delivery, they just sent it that way.
So all told, I spent about $60 on the pads and $75 on the rotors both at genuineaudiparts.com, plus the $140 on the tool from mactools ===> $275, which is still a bunch less than the stealership wanted and now I can do them whenever I want......
If you live in Connecticut and want to use the tool, send me a note offline....
#22
There is a cheaper, easier way than either tool, ECS has this:
http://www.ecstuning.com/Audi-C6_A6-...hecker/ES9950/
Just follow the procedure posted for the VCDS/Ross Tech tool (or basically the true VAG tool instructions). This is a full vag tool, stand alone. The only issue with it is the interface takes a little getting use to (in my opinion the buttons are backwards, but it works, and the menu of items isn't in numerical order (you just have to search through). But for $110(!), it's a full stand alone vag tool, easy to use, does everything the VCDS does (except for storing data, you can only view real-time).
I did the rears on my A6 a few months ago with this tool, and worked like a champ. (And for $110 it was easier than taking the calipers apart), with this tool I did the rears in about 30 minutes total (with new roters installed to boot).
#23
Also, you're not really "taking the calipers apart". You take 2 small screws out and turn another, it's very easy, you have the calipers in hand anyway. I'll bet that I could do it faster than someone can hook up the scanner and go through the menu and open the caliper pistons and then click on something else when the job is done to turn the pistons back in. The question is what's the proper way to do it by the book.
#26
http://wiki.ross-tech.com/wiki/index..._Parking_Brake
I would like to buy the v-checker pro also for 2006 A6 rear pad replacement. This link must be the instructions although I have never used the vag-com.
#28
"Thanks for the inquiry. Unfortunately the the v-checker can not perform that job. You will need a vag-com to do that. I have also seen a write up on the vw forums which shows you a DIY on how to do that without a vag-com. I believe you have to use a jumper wire from the battery. If you have any other questions please feel free to ask.
Best,
David Coleman - Sales Representative"
Based on this, I feel less certain about the V-checker. Emkawarrior, you obviously have it figured out - can you please post the procedure that you used? Thanks! Also, anyone know what he's talk ing about with respect to using a jumper from the battery?
#29
Gonna tackle this in the next few days on my '06 D3 A8- assume the vag-com instructions are the same... guess I'll find out! Figure I'll do the fronts first as they should be pretty standard, without any damned electronic parking brake to complicate matters.
#30
