Remote Start
#12
Stroker351w - Do you have the advanced key option in your car? Does the advanced key change the wiring and functionality? I was wondering what the process is to enter the car and drive away. A regular car without the advanced key usually requires you to put the key into the ignition and turn it to the ignition position then press the brake. Also another thing to worry about is the steering wheel lock.
BTW - Are you going to be able to program your Audi switch bladekey to control the remote start?
I'm pretty sure you will find a way but please post a DIY. Thank you.
#15
You can't program the switchblade for a remote start. You have to use the key fob that comes with the remote start. That being said, all you need is the most basic remote start because the keyless and trunk are on the key already. I would suggest the Viper 5301. That has keyless but the remote start is 2 way so the key fob tells you if the car started up. Otherwise you can go with the Viper 5101 which is only one way.
#16
I don't have the advanced key option in my A6 but, the functionality is similar. The Canmax 400 will be programmed for that option and you still have the 556uw with a valet key in it. When you get in you will have to hit the brake to turn off the remote start and then turn the car back on like normal. (Small price to pay for having a remote start in a great car).
#17
http://www.xpresskit.com/product.aspx?productid=81
You can find the manual and firmware links there.
#18
yes, that is the interface between the module and the computer. You are going to use the 400.AUKI firmware.
#19
Last question/concern is.. My previous car was a BMW and BMW disables the receiver for the key fob once the ignition has turned on making the key fob useless once remote started. The shop said I will need to then use the key and insert it into the hole to unlock the car. Is the Audi the same? I opted not to do it for the BMW since it was basically gaining one convenience and giving up another.
#20
