Replacing the DRL
I'm wanting to replace my yellowish DRL bulbs on my 05 A6 with something not so yellow. I know that the LEDs cause error codes, are there any bulbs I can shove in there without changing the housing to give it a more white or bluish look?
Try these http://www.tempestatuning.net/index....roducts_id=183 they work for me with no errors.
It's pretty easy. Drier side remove break fluid reservoir by lossin the ring around it an you can replace the bulb (I did) Passanger side just remove air box.
P.S. Maybe you can put some pictures to see how good they look on your car?
Will appreciate this
I also have a set of 1156 (drl bulbd) LED Bulbs and a set of 50watt 6ohm resistors if you are interested for $10+SH. (Check my other thread).
I chose halogen over LED because of the color output. Halogen ones math the factory HIDs way more.
Here is an example of my halagen ultra white bulbs installed; no errors.
