Replacing the DRL
#11
#13
Yes. Stick your hand in, slight push forward and about 30 Degree twist to the left. Passenger side (after air box is removed) is plenty of room to work with. Driver side is very tight and it was hard for me to make that twist and was even harder to put the bulb back in. I used needle tip pliers to twist the bulb in place
#14
i assume we cant get these halo bulbs in local parts store, reason being tomorrow i plan on doing maintenance and while I have air filter off i would like to change the DRL bulbs. If anyone knows of a seller in bergen county nj , i would appreciate the info.
#15
#16
#17
Also, when the headlights are off, because the bulb itself is blue, you inner headlight will look blue-ish. I like it but if toy don't might want to consider different Bulb without blue-ish tint to it.
#18
I bought these at Advanced Auto Parts and put them in. They are considerably brighter, but still have a yellow tinge. I don't know that I'm up for putting in another set, my hands are kind of large and very torn up.
before
![Name: JucnN.jpg
Size: 121.5 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/104783d1683158554-replacing-drl-jucnn.jpg)
after
before
![Name: JucnN.jpg
after
![Name: spCnL.jpg
Size: 60.2 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/104784d1683158554-replacing-drl-spcnl.jpg)
#20
Yes, I've tried these. Founf them in Advanced auto parts. The box claimed to be 25% brighter but ones I ttested them prior to putting them in, they were just as yellow as my current bulb (seen from the picture). I went and bought a set from ebay (my picture). They were ~$5 and are pretty white.
