When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
As I've talked about on my other thread my esp is giving a fault for G419 sensor no communication. I've replaced it but the fault wont clear. Looking in the service manual it says I must use guided fault finding and select replace for the control module. I have a 5051a and a vag com. Is there a way to do this in vcds? See screenshot Guided fault finding? Replace g419 i cant find it in the software.
I found these instructions on the vcds website at this link... they are for a a4 8e but look like they might be applicable to me. can someone confirm?
ESP-Sensor Unit (G419)
[Select] [03 - ABS Brakes][Security Access - 16]
Enter 40168 [Do It!][Basic Settings - 04]
Group 069 [Go!]
Field 2 should show OK after a successful Calibration. [Done, Go Back][Meas. Blocks - 08]
Group 010 Field 1/2 (Longitudinal Acceleration Sensor (G251))
Specification: ±1.25 m/s² [Done, Go Back] [Fault Codes - 02]
All fault codes should have disappeared. [Done, Go Back][Close Controller, Go Back - 06]
Replacement
After Replacing or Coding this Control Module these Steps have to be performed in the following Order:
In case you are having trouble with procedure please contact us directly and we will assist you with the Coding Process. Every inquiry on this topic has to include a full Auto-Scan as well as which parts have been replaced and why, also make sure the Auto-Scan includes the complete VIN of the vehicle in question.
Where did you find the sensor? i’ve got the fault on my 2005 A4 3.2. is it under the passenger seat floorboard?
it has beem many years but if i recall its either in front of the firewall behind the engine on the right hand side if standing and looking at the car. If its not there, it might be part of the abs system... but i would probably need to see a picture of the replacement part to remember. that was in a 2006 a6 or s6 c6 series.
