A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Replacing only 2 tires
Old 07-13-2018, 03:12 PM
  #11
akingzkid's Avatar
Originally Posted by UCLABB
Okay, someone will blast me for this, but how about running a little more air pressure in the fronts to help even out the circumference?
ULABB,
How about this..............I was just doing more research and I see lots of people saying that an option is to have a tire shop shave some rubber off of the new tires to bring them down closer to the circumference of the old tires. My old tires are at 4/32 (not too bad). My new tires are at 7/32 or 8/32 depending on where you measure them. If I got them to shave them down to 6/32 that would bring me to a diff of 2/32 between my old and new. I know that sounds crazy but I could probably have that done for $25 per tire ($50 total). And the tires would probably still last me 2 years. I'm thinking about it.
Old 07-13-2018, 03:13 PM
  #12
akingzkid's Avatar
Originally Posted by KevinGary
I also wouldn’t replace only 2 tires. I would replace all 4 at the same time.
Thanks for your feedback KevinGary. I have come to the conclusion that you are rich. You spare no expense.
Old 07-13-2018, 03:14 PM
  #13
akingzkid's Avatar
Originally Posted by raj99
I wouldn't but that's me..I think 4/32" is too far a gap and would stick with 2/32", since binding the diff and causing excessive wear ain't that great. If you rotate tires, you won't have too much delta between your front and rears, so you only need to change them all at once vs. the 2 at a time. Also, I've found that sale of 4 tires tend to be better than 2 tires.
Thanks Raj. And I agree with buy 4 is cheaper than 2. I could have gotten a $50 rebate if I got all 4 of these. I will call them and see if they can still give it to me if I go back and get 2 more. Thanks again.
Old 07-13-2018, 03:55 PM
  #14
808juiceman's Avatar
Replace all 4 tires. This is a Quattro Audi!
Old 07-13-2018, 05:15 PM
  #15
Nurke's Avatar
There is an old saying in Balkans poorly translated..."while there are sheeps...there will be wool".
it is like when they tell you you need wheel alignment if you want to change tires...but you need tires bc you never inflated them properly not bc you hit the curb..the if you need alinment the you will need come more parts since alignment us not somthing that wears out..ball joins are....omg...
2/32 is the minimum for safety inspection to pass..4/32 would be time to change it..you want to have deeper tread to expel water..or you will be hidroplaning...
there is a little " bridge" between two lines of treads..then those treads are even..you got 2/32 depth...you can feel it if you put the finger between those treads and follow around...
i never worried about ruining diff or trans...if you have rubber fighting metal gears...what do you think will win?
Old 07-14-2018, 03:22 AM
  #16
KevinGary's Avatar
Food on the table, roof over my head and my bills are paid.
badabbott
05-09-2011 02:40 AM
joedirt1
11-05-2009 07:40 PM
rexwilson
08-15-2006 07:49 PM
Kricka
11-03-2003 01:31 PM
valium
Motorsport Discussion
07-16-2003 01:11 PM
Quick Reply: Replacing only 2 tires
