REPLACING REAR BRAKE PADS WITH VAG COM??
Do I actually need the vag com to change my damn brakes. Is there any way around that at all?? What exactly do I do with the vagcom to change the brakes. cant seem to find a diy or instructional.
Thanks
Thanks
You have to spin back the piston. Apply a small amount of pressure to the piston and turn it clockwise, I used a rear wheel disc brake piston tool, purchased at pepboys. Grab some channel lock pliers and twist them back while applying a small amount of pressure. It took about 10 minutes a wheel because it was a bit tedious but it saved me $500 at the dealer.
