S6 - Offf Idle Stumble
My new-to-me 08 S6 (23k miles) has a most annoying off-idle hesitation. It occurs at about 1,000 rpm under gentle throttle. When the hesitation occurs, I often add more throttle and then over-control. (Oh, what I would do for a manual transmission). It is especially annoying in heavy traffic.
Dealer has checked a couple of times and has reprogrammed the transmission computer which improved things but only slightly.
Have any of you experienced this stumble? It seems to me an engine problem, maybe injectors, not transmission. Any solutions??
Eric
(84 Olympic, 95 S6, 08 S6)
Eric
Eric
Eric
Just a guess, since direct injection engines are known for this.
I was told by an Audi tech friend of mine that no one with an S6 has been witnessed with the carbon buildup in the engine. Plus, with only 20K on the car I don’t think that it would the issue.
With that said, there were some service bulletins for S6. Has your car had all of them performed? I remember something about a coil pack.
In a worst case scenario, if you are not getting anywhere with this dealer try another one. So far the only issue I came across was a tranny one that I did a write up on a while back.
https://www.audiworld.com/forums/sho....php?t=2749449
I've read of issues with carbon buildup as early as 7500 miles (IIRC), but this was on an B7 RS4.
Vegas - i read your previous tranny issue.. I went from an 08 3.2 to the 07 S6 and on the S6, there is a very noticeable lag when engaging Drive from reverse. The car keeps rolling back a bit before Drive is engaged. My 3.2 engages immediately..
Is that normal on the S6? The car is going in for coil pack recall tomorrow.
Mine rolls back too before the D kicks in after the shift on an incline, but I monitor that and am very gentle when going from reverse to drive by not hitting the gas and using the breaks. Doesn't really bother me as it only happens when pulling out of my drive way.
bitjockey (bum)
02-14-2006 01:18 PM
Mitch S6 Avant
19
07-01-2004 04:45 AM
Afroide
01-27-2003 12:38 PM
S4TNT
10
09-21-2001 06:19 PM
