Satellite Radio Volume "Currently Unavailable"
#11
Update, for what it is worth.
Happened again today. Unable to adjust volume on Sirius stations after starting the car. Switched over to a FM station, adjusted volume and went back to Sirius and new volume level maintained. Turned off car when arrived at work and restarted: still unable to adjust volume on Sirius stations only. When started car to return home, everything back to normal.
What I did notice when starting the car was a Sirius updating channels notification in my dash display. So, seems to remain a Sirius issue.....
#12
#13
Brand new car and have spent hours with SiriusXM tech support which finally gave up on me an said I need to take it to the dealer. The dealer said it has been happening to two other cars they know about and that they think it is a software problem. I emailed the service manager today to see what they are going to do to repair the issue. Has anyone had luck fixing this since I see the problem has been going on for many years with Audis.
#14
My problem was finally resolved by having a new shark fin antenna installed.
Now I'm having problems sporadically losing my gps satellite signals, so I'm having the car looked at (for the third time.)
#15
Since last post, has happened a few more times, only when Sirius was updating on my way to work.
Volume remedy remains the same: switch to FM, adjust volume to desired level and return to Sirius channel. When I restart car after work, everything is fine.
Do not feel it warrants taking to dealer, which could end up causing more issues as PaulEF just encountered. Forgive the pun, but feel this is a only a Sirius but not a serious enough issue to address.
#16
On Thursday, March 2, 2017 - Audi of North America confirmed that "there is a software problem with your 2017 A3 and engineers in Germany are aware of the problem." They did not give me an expected repair date nor do they have a replacement option at this time.
#17
Audi A3 / S3 /RS 3 MKII - AudiWorld Forums
#18
While this might not be an explanation for all those here with issues, Sirius will update their lineup from time to time. This can cause an outage for a period of time. Since there are several reports here of problems yesterday, my guess would be that's why Sirius was not available.
