When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Ok, I have been going crazy searching the internet looking for instructions on removing the seat control panel, on the right side specifically. The front part and the top comes off easily enough, but I can't seem to get the back of the panel to release and I don't want to break anything. There are like three (FOUR if you count the seat belt cover) separate trim pieces that come together on the side of the seat and as much as I look at the three parts individually on the internet, I can't wrap my head around how they are joining together and what is holding who where?
1 - Backrest
2 - Side trim (sill side; rear)
t Removing
– Remove seat → Chapter.
– Attach seat repair stand -VAS 6136- to engine and gearbox support -VAS 6095-.
– Attach front seat to seat repair stand -VAS 6136-.
– Detach fastening strip of footwell trim from side trim → Fig..
– Apply screwdriver to head of plastic rivets -3- (2x).
– Twist screwdriver to prise out plastic rivets -3- (2x).
– Unscrew bolt -4-.
– Disengage rear side trim -2- upwards at retainer -5-.
– Twist rear side trim -2- in direction of arrow to separate it from front side trim -8-.
– Slide side trim -8- forwards to disengage lug -7- from bracket -11-.
– Disengage front side trim -8- upwards at retainers -6- (2x).
– Open fastener -9-.
– Unplug connectors -10- (3x).
– Detach front side trim -8-.
t Installing
Install in reverse order of removal. Note the following:
– Insert fastening strip of footwell trim in retainers on side trim → Fig..
3 - Plastic rivets (2x)
4 - Bolt
5 - Retainer
6 - Retainers (2x)
7 - Lug
8 - Side trim (sill side; front)
9 - Fastener
10 - Connector (3x)
11 - Bracket
12 - Side trim (tunnel side)
13 - Plastic rivets (2x)
1 - Backrest
t Removing
– Unscrew bolt -4-.
t Installing
4 - Bolt
5 - Retainer
6 - Retainers (2x)
7 - Lug
9 - Fastener
10 - Connector (3x)
11 - Bracket
Disconnecting fastening strip of footwell trim
– Disengage fastening strip -1- of footwell trim -2- from retainers -4- (2x) on side trim -3-.
Or this
seat frame (electrically; adjustable); front
seat frame (electrically; adjustable); front; PR-3L4,3L5,; 3PN
1 8E0881157K seat frame (electrically; adjustable) but without motor; modify in workshop; left 1
1 8E0881158K seat frame (electrically; adjustable) but without motor; modify in workshop; right; PR-9P1,9P3,; 9P7 1
1 4F0881158 seat frame (electrically; adjustable) but without motor; right; PR-9P5 1
2 8E0881303 spring mat; left,right; PR-9P1,9P3,; 9P7 2
2 8E0881303 spring mat; left; PR-9P5 1
3 8E0881621 clip; PR-Q1D X
4 8E0857781B seat belt guide; left 1
4 8E0857782B seat belt guide; right 1
5 4F0881713 edge protection; left a. right; 100MM 2
6 8E0881183D guide rail for seat with motor; for longitudinal adjustment; item/s to be included:; left; 5 1
6 8E0881184D guide rail for seat with motor; for longitudinal adjustment; item/s to be included:; right; 5 1
7 seat adjustment motor for; rake adjustment; see illustration:; 959-20
8 seat adjustment motor for; height adjustment; see illustration:; 959-20
9 8E0813477A bracket for child seat; for seat:; -isofix-; passenger side 1
10 N 10622701 hexagon socket head panel bolt; 6,3X16 4
15 8E0881559A retaining bar; left 1
15 8E0881560A retaining bar; right 1
16 4F0881317 seat frame trim; left outer 1
4F0881317 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881317 Y22 linen beige; -GS
4F0881317 8Y4 amaretto brown; -NM
4F0881317 J50 light grey; -GV,GW
4F0881317 K38 cardamom beige; -GX,GZ
4F0881317 Z95 pearl silver; -SE
16 4F0881318 seat frame trim; right outer 1
4F0881318 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881318 Y22 linen beige; -GS
4F0881318 J50 light grey; -GV,GW
4F0881318 K38 cardamom beige; -GX,GZ
4F0881318 8Y4 amaretto brown; -NM
4F0881318 Z95 pearl silver; -SE
17 4F0881477 seat frame trim; left outer 1
4F0881477 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881477 Y22 linen beige; -GS
4F0881477 J50 light grey; -GV,GW
4F0881477 K38 cardamom beige; -GX,GZ
4F0881477 8Y4 amaretto brown; -NM
4F0881477 Z95 pearl silver; -SE
17 4F0881478 seat frame trim; right outer 1
4F0881478 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881478 Y22 linen beige; -GS
4F0881478 J50 light grey; -GV,GW
4F0881478 K38 cardamom beige; -GX,GZ
4F0881478 8Y4 amaretto brown; -NM
4F0881478 Z95 pearl silver; -SE
18 4F0882327C cover cap; left 1
4F0882327C 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0882327C Y22 linen beige; -GS
4F0882327C J50 light grey; -GV,GW
4F0882327C K38 cardamom beige; -GX,GZ
4F0882327C 8Y4 amaretto brown; -NM
4F0882327C Z95 pearl silver; -SE
18 4F0882328C cover cap; right 1
4F0882328C 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0882328C Y22 linen beige; -GS
4F0882328C J50 light grey; -GV,GW
4F0882328C K38 cardamom beige; -GX,GZ
4F0882328C 8Y4 amaretto brown; -NM
4F0882328C Z95 pearl silver; -SE
19 4F0881559A retaining bar; left 1
19 4F0881560A retaining bar; right 1
20 8E0881331A oval head panel screw; M5X8 X
21 8E0881712B panel nut X
22 N 91055802 speed nut; M5X29,4X20,3 X
23 4F0881327 cover cap; for seat:; right inner; left 1
4F0881327 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881327 Y22 linen beige; -GS
4F0881327 J50 light grey; -GV,GW
4F0881327 K38 cardamom beige; -GX,GZ
4F0881327 Z95 pearl silver; -SE
23 4F0881328 cover cap; for seat:; left inner; right 1
4F0881328 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; SC,ZM,LR
4F0881328 Y22 linen beige; -GS
4F0881328 J50 light grey; -GV,GW
4F0881328 K38 cardamom beige; -GX,GZ
4F0881328 Z95 pearl silver; -SE
24 8E0881500 spreader rivet X
8E0881500 01C satin black
30 8E0881055 seat depth adjuster-; upper part; left a. right; PR-Q1D,Q4Q+; 9P1,9P3,9P7 2
30 8E0881055 seat depth adjuster-; upper part; left; PR-Q1D,Q4Q+; 9P5 1
31 8E0881061 seat height adjuster; lower part; left a. right; PR-Q1D,Q4Q+; 9P1,9P3,9P7 2
31 8E0881061 seat height adjuster; lower part; left; PR-Q1D,Q4Q+; 9P5 1
32 4F0881793 trim for seat cushion depth; extension; left,right; PR-Q1D,Q4Q+; 9P1,9P3,9P7 2
4F0881793 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; ZM,SC,LR
4F0881793 Y22 linen beige; -GS
4F0881793 J50 light grey; -GV,GW
4F0881793 K38 cardamom beige; -GX,GZ
4F0881793 8Y4 amaretto brown; -NM
4F0881793 Z95 pearl silver; -SE
32 4F0881793 trim for seat cushion depth; extension; left; PR-Q1D,Q4Q+; 9P5 1
32 4F0881793A trim for seat cushion depth; extension; also use:; right; N 014 002 1; PR-Q1D,Q4Q+; 9P5 1
4F0881793A 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; ZM,SC,LR
4F0881793A K38 cardamom beige; -GX,GZ
- N 0140021 countersunk panel screw; 6,3X22; PR-Q1D,Q4Q+; 9P5 3
- 4F0881547 retainer for trim; seat depth adjuster; right; PR-Q1D,Q4Q+; 9P5 1
33 8E0883253A handle for seat front edge; adjustment; left,right; PR-Q1D,Q4Q+; 9P1,9P3,9P7 2
8E0883253A 6PS soul (black); -MF,NK,NL,NM,; QE
8E0883253A 4PK soul (black); -GD,GT,QE,QF,; QL,QQ,QX,ZM,; GS,GU,LR,SC,; SE
8E0883253A 8C1 torrone (beige); -NR
8E0883253A J50 light grey; -GV,GW
8E0883253A K38 cardamom beige; -GX,GZ
33 8E0883253A handle for seat front edge; adjustment; left; PR-Q1D,Q4Q+; 9P5 1
34 8E0881712A hexagon collar nut; self-locking; M6; PR-Q1D,Q4Q 8
35 padding for seat depth; extension; see illustration:; 881-60; PR-A8S
35 padding for seat depth; extension; see illustration:; 881-61; PR-A8U
50 seat padding; see illustration:; 881-60; PR-A8S
50 seat padding; see illustration:; left; 881-61; PR-A8U
50 seat padding; see illustration:; right; 881-61; PR-A8U+9P1
50 seat padding; see illustration:; right; 881-65; PR-A8U+9P5
51 seat covers; see illustration:; 881-60; PR-A8S
51 seat covers; see illustration:; 881-61; PR-A8U
52 8E0881954 hex socket head locating bolt; M8X17 X
53 4F0947113 bracket; PR-QQ1 2
4F0947113 4PK soul (black)
54 4E0947415 light; LED; PR-QQ1 1
- 4F0857225 intermediate layer; right; PR-A8U+9P5 1
55 N 90936901 socket head collared bolt with; inner multipoint head; M10X38 8
60 8J0882621 stowage compartment; left 1
8J0882621 4PK soul (black)
60 8J0882622 stowage compartment; right 1
8J0882622 4PK soul (black)
61 8J0882625 insert for stowage compartment; left 1
61 8J0882626 insert for stowage compartment; right 1
62 4F0882251 handle; stowage compartment; left 1
4F0882251 4PK soul (black); -GD,GT,QE,QF,; QL,QQ,QX,ZM,; GS,GU,LR,SC,; SE
4F0882251 J50 light grey; -GV,GW
4F0882251 K38 cardamom beige; -GX,GZ
62 4F0882252 handle; stowage compartment; right 1
4F0882252 4PK soul (black); -GD,GT,QE,QF,; QL,QQ,QX,ZM,; GS,GU,LR,SC,; SE
4F0882252 J50 light grey; -GV,GW
4F0882252 K38 cardamom beige; -GX,GZ
63 4F0882627 trim; stowage compartment; left 1
4F0882627 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; ZM,SC,LR
4F0882627 Y22 linen beige; -GS
4F0882627 J50 light grey; -GV,GW
4F0882627 K38 cardamom beige; -GX,GZ
4F0882627 Z95 pearl silver; -SE
63 4F0882628 trim; stowage compartment; right 1
4F0882628 4PK soul (black); -GD,GT,GU,QE,; QF,QL,QQ,QX,; ZM,SC,LR
4F0882628 Y22 linen beige; -GS
4F0882628 J50 light grey; -GV,GW
4F0882628 K38 cardamom beige; -GX,GZ
4F0882628 Z95 pearl silver; -SE
64 N 10430103 hexagon socket flat; head bolt; M5X16 8
65 N 90475903 speed nut; M5X13,6X11,5 8
