Sirius - saved stations
Is there any way to delete or change the saved Sirius and FM stations on the MMI screen? When Sirius changes station numbers and names, the screen doesn't update and I'm left with presets for stations that don't work or I don't want. The same is true for FM stations - although the names grey out when they're not available.
Thanks
Thanks
Thanks
Thanks
You can delete them all. Click sirius button then click setup. It is in there. Look for delete saved station or something similar. I did this a few months ago.
Thanks for the responses but neither works for me. I can't save a station to an occupied preset. The reset to factory default setting doesn't do anything. I have a 2005 with the original MMI software (no upgrades) if that makes a difference.
Something doesn't seem right. You should be able to save a new preset over an old one. When XM changed station names, I re-saved it over the old one and it updated the memory. What good are presets if you cannot change them after you initially save a station?
Cat Herder
MMI update should take care of it. I don't have this issue at all.
SOASOAS
04-26-2007 10:06 AM
DeutschDriver
09-27-2004 01:21 PM
