Is their such thing as 2 glove boxes for AMI?
AMI question on C6. Dealer's Quote
I am looking to get AMI installed on my 2005 A6. My dealer quotes me $2,100 for the install. I feel like that is a bit much. They said that they need to install a new glovebox as the 05 model will not fit the AMI. Is this true?
I look on genuineaudi parts and I see the same glovebox for all years. Also the retrofit kit is $800 online. I feel like I am being overcharged for both parts, labor and unnecessary parts. Can someone verify what I actually need? And around how many hours it would actually take for labor?
Thanks
Thanks
I'm doing it myself right now and it can be done in 1-2 hours. You can get the whole AMI kit for $775 on genuineaudiparts.
As for the glovebox, search the forum. you will find a thread about cutting out the rear opening of the glovebox to be able to slide the AMI all the way in, assuming you already have the rack in it where the CD changer sits.
Thanks
Thanks
Thanks
Thanks
Haven't gotten around to it yet...it doesn't move around while the glove box is closed, else it would have moved up my list
Good point, reminds me of an item on my to-do list - while you have your Dremel out, you can also cut a couple of the security slots - one on each side of the right hand bay - which will allow the AMI to lock into same. Figure you can use the left bay to determine location, depth of the ones you need to cut for the right.
I did mine myself. took awhile. If I had it to do over again I would've had someone else do it because of the amount of time and tools it took. Not the dealer though because they were adamant about the glovebox replacement. There are car audio places that'll do it though.
IIRC, DirtyVegasTT sourced the parts himself and then had the dealer do the install.
I totally agree with landjb4u, if I had to do it all again I would have had someone else do the install for me, a quality custom audio/car electronics place or similar that would be willing to show creativity to solve the glove box issue but not go quoting 4-6 hrs to do the whole job...
Bryan72880
21
06-06-2009 05:45 AM
ScratchRob13
02-09-2009 06:04 PM
canadian dealers smoking weed? They now tell me cd changer has to go or be replaced for AMI to fit??
06A8
14
02-12-2008 03:22 AM
ricestang
12-04-2006 06:14 PM
