Tiptronic Shifter button - broken pull-up rod
#11
This should have been an easy job, but Audi has created a 8 job to replace teh shifter linkage. To begin with, the plastic rod that is shown in the above photos is not available from Audi as a replacement part. The only option is to replace the entire shifting mechanism. Or make your own. I chose the later option. Made from a stronger plastic stock and fitted with a laser cut fitting/catch mechanism, I think I created a better part than the original. Okay, so I'm boasting.
Removing the shifter assembly requires removing the following:
1) Most items above the drive shaft tunnel including the arm rest,
2) Exhaust system
3) Drive shaft
4) Shift linkage to transmission
5) Shifter housing
Be sure to have the nice VAG socket drivers. A regular torx set will not do the job.
I am amazed how difficult it was to do compared to a "normal" car. Tight packaging has some negative consequences.
I can post pics if people are interested.
2) Exhaust system
3) Drive shaft
5) Shifter housing
#13
Hello people,
does anybody of you guys can provide some pictures of the fix?
My shift **** button stays inside at audi c6, after dissasembling everything it shows up that pull up rod is broken - dont ask me how...
Thanks for help!
Thanks for help!
levansula
24
01-26-2021 04:02 AM
Galco
54
11-03-2018 02:13 AM
