Tires do not match...OK?
I bought my 2005 A6, 4.2 several months ago. I noticed the tires are not the same kinds. The front two are the same and the rear two are the same. Is this OK? They are the same size and speed rating; the tread pattern is close to matching but not identicle.
I had a Grand Cherokee full time four and that transfer case is very sensitive to different tires. That had to have the four tires the same.
Quattro is also very sensitive, maybe even more. I would have the same tires all the way around, with approx. the same tread life as well.
It's enough to make you think hard when the tire places pitch the extended/hazard insurance packages when you purchase a new set of tires, given the ramifications (costs) should you lose one...
With similar sizes and wear you should be fine. The system is not as sensitive as we are consistently led to believe. The reason? Well, Audi techs and sales people run staggered setups... when I asked them about the tranny issue on our cars they said that it has a certain tolerance for these type of things.
If anyone is that adamant about this not being the case, then tell us how many tranny issues have there been related to offset or uneven tires? And yes, there are plenty of people running offset tires on Quattros.
good (and valid) point
<...> The system is not as sensitive as we are consistently led to believe. <...> when I asked them about the tranny issue on our cars they said that it has a certain tolerance for these type of things.
As to the question of exactly what the tolerances are, what configurations are worst/most likely to lead to failure, how long (miles) the car has to be in a configuration to get to a failure point - whew, I'm sure that data is available, but I would also hazard it's likely also Audi-internal and probably extremely confidential
Sorry if my comments made it seem I was being adamant/"intolerant" on this - not my intent.
To the OP: if I was in your situation, and the rating & wear on the two pairs were roughly equivalent, I would keep things as-is until it's time for new tires, at which point I personally would go for a new (matching) set of 4.
my $0.02....
valium
Motorsport Discussion
07-16-2003 01:11 PM
