Too much ATF?
Guys,
The car is C6 A6 3.2 Quattro. The transmission is ZF 6HP19A. The tranny goes in limp/safe mode after 100 yards, so I decided to check the ATF level. I placed the car on jacks, brought the transmission to 35 degrees, put it in Park and opened the fill plug. Oil started coming out like crazy. I got half a litre out and put the plug back in. I decided not to wait until 40-45 degrees (per manual) since even more fluid would come out.
My question is how/why can this transmission be overfilled?! Even if you fill it at 0 degrees, I don't think you can get this much oil in. Can overfilling put it in limp mode? Could it be that the pump is faling and not sucking oil? Does the pump actually suck the oil or is it lubricated by the rotation of the gears?
Should I let all the excess oil come out? What can I do here? I need some advice badly!!!
my tranny went safe mode couple of times too... i was told. low battery...and now shifts hard and acts up.. i dont know wtf is wrong , i got 95K on ....
Improper gear ratios for 5th gear and reverse gear and torque converter issue. How many miles have you driven the car since purchasing it and was it a private or dealer deal?
I believe that the tranny fluid should be blue or green depending on the year of the car. So the fact that it is black is not good. Perhaps it is burnt or someone filled it with the wrong fluid.
The pump is on the input shaft behind the torque converter. It pull fluid from the pan and lubricates and pressurizes the hydraulics. It is a gear type pump.
To properly check the fluid the engine must be running in idle and the fluid between 35 and 45C. This makes sure that the pump has filled the tranny with fluid. If you open the drain and the engine is not running then you will get a large amount of fluid out of the drain.
Here are the instructions for filling.
Remove the ATF inspection plug - arrow B - .
Guide the filler hook of the ATF filler tool VAG 1924 into the opening - arrow - of protective cap, do not push the cap up and in while doing so.
Add the ATF using the ATF filler tool VAG 1924 until ATF drips from the inspection opening.
Place the selector lever in the "P" position.
Start the engine and switch off again after 20 seconds.
Once more, add ATF using the ATF filler tool V.A.G 1924 until ATF drips from the inspection opening.
Start the engine.
Continue adding ATF using the ATF filler tool V.A.G 1924 until ATF drips from the inspection opening again.
Tighten the ATF inspection plug.
With the engine idling, press the brake pedal and shift the selector lever through all the selector lever positions, leaving the selector lever in each position for at least 10 seconds.
Place the selector lever in the "N" position.
Increase the engine speed to 2000 RPM and maintain for at least 60 seconds.
Check the ATF level and top off.
Start the engine.
You are correct - it shouldn't be black. My transmission should be filled with yellow fluid since it has the initial software release. I'm not on blue yet as that would require the software to be flashed.
Here are the instructions I followed (combined with the Elsawin instructions from another user): http://www.zf.com/na/content/media/u...9A_Catalog.pdf
Please note that the instructions are per the manufacturer of the transmission.
