Last edit by: IB Advertising
- Audi A6 C6 How to Change Manual Transmission Fluid<br>Step by step instructions for do-it-yourself repairs.
- Audi A6 C6 Quattro System Fluid Change<br>Step by step instructions for do-it-yourself repairs.
Trans, diff and transfer case fluid change
Decided to start a new thread to consolidate wisdom. I have done a lot of reading already, but could not find a good pic of where the drain/fill plug is for the front differential on an A6 quattro system.
Transfer case: https://www.audiworld.com/forums/sho....php?t=2752978
Transmission is pretty obvious: http://www.ehow.com/how_5000414_chan...i-quattro.html
Rear diff is pretty obvious
Where is the drain/fill hole on the front differential?
I put the car on ramps last night and looked around for 15 minutes and couldn't find anything that looked like a drain/fill plug.
I attached a pic of the trans. Just to verify, the upper plug is the drain and and the bigger plug on the bottom is the fill right? I have not had a car that had the fill plug on the bottom with a riser like that.
There must be something obvious I'm missing with the front differential. I do maintenance on 3 different Jeeps so I know my way around 4WD systems pretty well.
Thanks for any help!
I did the change of the diff and crank case fluids less than 2 months ago.
The front diff fluid can be accessed from the passenger side of the diff and needs to be extracted out with a pump. There is no 'drain plug', you will need to pump the fluid out and then replace it the same way. This is the same for the rear diff, which also needs to be extracted. The only one which has an actual drain plug is the crank case (center) and it's pretty obvious.
I wish I'd taken pics of when I did the change. FWIW, I did not need to remove the passenger wheel liner, but then again I had a lift.
Awesome, thanks for the info!
I was going to use a tool like this: http://www.harborfreight.com/oil-suction-gun-95468.html
Looks pretty useful for putting the fluid back in too.
I have tried other fluid suction tools and they all seemed to suck.
sounds good, but if I recall the rear diff needs to go 'up and over' and needs to have some sort of syphon like the following plastic portion: http://www.harborfreight.com/5-gallo...ump-95068.html
so that you can pump oil over the lip, without just shooting it in and hoping that it's going in.
Also, I ended up using a friends electric extraction unit like the following which worked GREAT:
I bought this one in preparation for the same job (it pushes liquids too):
Interesting that you did not have drain plugs for the front and rear diffs. Guess I will find that out soon too.
on my 4.2 there were no drain plugs, just fill plugs
The only difference between the tool you (cal3thousand) have vs. the one I used is that the one I had runs through an air compressor and hence requires no manual pumping.
Really good info. I really appreciate the help on this topic. I'll get the kit from thectsc with Lifeguard 6, filter and gasket and I should be good to go. Thinking I'll go Amsoil for the transfer case and diffs. My VAGCOM should be here tomorrow so I can start poking around with that too. I'm used to the fluid temperature check. I had the same thing on my Mercedes, but I just used an IR temperature reader on the pan. At least that had a dipstick to make it easier.
Pulled the passenger side wheel and found the fill plug. Also got to look at the front suspension. All the ball joints look to be in good condition and all the rubber bits look good too. I was a bit worried with 67k miles. I'm assuming the previous owner did not drive it really hard, which is fine with me.
I'm assuming the fill plug is what I have circled in red?
