UK: Heavy steering after fluid change.
#11
depends if you have the belly pan or it is already lost. I consider it a PITA to replace the belly pan with a jack only.
I think you can remove the trim around fog lights and see if you can access the radiator pipes there. Just be sure that those are the power steering lines and not the oil or transmission lines.
#12
Instead of. the pipe is the lowest point in the system and it guarantees that you will get all liquid out.
jerobean
09-26-2022 12:08 PM
S4Ca$hwhore
9
10-25-2006 12:53 PM
mxp
03-18-2002 02:52 PM
Hoodini
08-13-2001 07:42 AM
