A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Used A6: Advanced Key Issues or Nomal
Old 06-15-2009, 11:52 AM
triplecore's Avatar
Default Used A6: Advanced Key Issues or Nomal
I have the advanced key on a 2005 A6. Is it normal that if i start with the advance key and drive and then then turn it off with pressing stop, (so I guesss it is in Acc mode)because I can still play with MMi. The problem is when I press Start the Dashlight come on but the car does not start? It like when i push the start button without the brake pedal, but I know I am pressing it. If stop and leave the vehicle and take the key with me and come back then it start without issue.
Starting the car manually is never a problem. Thanks
Old 06-15-2009, 11:53 AM
triplecore's Avatar
Mainly is it normal not to be able start the engine with adanvce key if you turn off the car without leaving it.
Old 06-15-2009, 12:25 PM
Cat Herder
pierreb's Avatar
try opening then closing the driver's door, then hitting the start button again. it's probably a feature to prevent unintentional stop/starts.
Old 06-15-2009, 05:26 PM
triplecore's Avatar
Does it use batteries? I have not had an issue unlocking with it or getting the vehicle to turn on but sometimes it wont start i have open the door or press the button more times.
Old 06-15-2009, 07:14 PM
RDD
RDD's Avatar
when I bought my CPO '05 1.5 yrs ago the push button go was updated to a newer version because it would crank a little longer than normal. Fixed it. Maybe that will help.
Kenzie Buettner
New Member Welcome Area
06-15-2017 12:30 PM
buggy15
A6 (C7 Platform) Discussion
12-28-2014 06:00 AM
jak2jak99
A7
10
01-02-2012 05:25 AM
NY_Q7
Q7 MK 1 Discussion
12-29-2006 09:11 AM
daveny
12
10-28-2005 03:50 PM
Quick Reply: Used A6: Advanced Key Issues or Nomal
