VAG: 008199 - Intake Manifold Flap; Bank 2 - Stuck Closed
Need help to translate a VAG tool error please.
Car is an 07 AUDI S6.
I'm interested in purchasing the car and I was wondering if this is a major/minor issue.
Prelim searches showed in the range of $1600+ (indie) job. Costlier via dealership.
Thanks in advance.
Address 11: Engine II Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09--- Serial number:
Coding: 01050009190F0160
Shop #: WSC 22198 444 84161
VCID: 2241FF4AFDD4D09
1 Fault Found:
P2007 - 001 - Stuck Closed - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 8
Mileage: 52309 km
Time Indication: 0
Date: 2012.03.02
Time: 07:20:29
Freeze Frame:
RPM: 1536 /min
Load: 37.2 %
Speed: 70.0 km/h
Temperature: 65.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Thanks in advance.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Mileage: 52309 km
Time Indication: 0
Date: 2012.03.02
Time: 07:20:29
Freeze Frame:
RPM: 1536 /min
Load: 37.2 %
Speed: 70.0 km/h
Temperature: 65.0°C
Temperature: 18.0°C
Voltage: 13.462 V
I would check for carbon build up in intake manifold near heads, had the same problem and it turned out to be this.
Replaced manifold but im sure cleaning could work.
Also check for actuator and sensor.
blowna499
30v V6 Discussion
06-12-2006 07:38 AM
