VAG Codes, any anyone have link(s)?
Somebody had posted this on Audi World in April, I can't remember their name. Anyway, here's the english version of it.
{AUDI A6 (4F)} in the AUDI A6 (4F) 2 communication possibilities for the eigendiagnose are used, on the one hand are also further possible a diagnosis over the used k-line, however limits to the engine expensive equipment and autom. Transmission. On the other hand all controllers are accessible over the CAN bus diagnosis.
The eigendiagnose should take place with an CAN able test equipment, thus can all controllers be addressed.
The following controllers are already here contained:
- longitudinal control
- Airbag
- trailer recognition
- brake electronics
- indicator/control unit (in front)
- automatic transmission
- electrical system I
- electrical system II
- a park assistance
- parking brake
- combination instrument
- comfort system
- steering wheel electronics
- shining width adjustment
- engine electronics
- level control
- tire pressure monitoring
- satellite radio
- telephone/mobile phone preparation
- door expensive devices
- entrance/starting authorization
- auxiliary/condition heating
{Airbag}
Controller coding
STG 15 (Airbag) select
STG coding - > function 07
Note: Due to the large number of possible codings you ask please a specific inquiry with part number and appropriate index by email.
Controller adjustment
STG adjustment - > function 10
Over the adjustment the Airbageinheiten is activated, and/or deactivated, depending upon motor vehicle type and/or model must be available not all channels.
0 - activates
1 - deactivates
- > channel 01 (AirbagBeifahrerseite)
- > channel 02 (Airbagdriver's side)
- > channel 03 (SeitenairbagBeifahrerseite)
- > channel 04 (Seitenairbagdriver's side)
- > channel 05 (belt-tautBeifahrerseite)
- > channel 06 (belt-tautdriver's side)
{trailer recognition}
Controller coding
STG 69 (trailer recognition) select
0000?xx: Handwheel
0 - without serving aster
3 - Handwheel for mechanical swiveling function
0000x?x: Trailer connector set
0 - without mechanical swiveling function
3 - mechanical swiveling function
0000xx?: Land selection
1 - Remainder of the world (RdW)
2 - The USA
3 - Australia
{indicator/control unit (in front)}
Controller coding
STG 07 (indicator/control unit in front) select
?xxxxx: Vehicle configuration
+1 - Driver information system (FIS)
+2 - Ausfuerung South America
+4 - 4-Tasten-Bedienteil
x?xxxx: Vehicle configuration
+1 - internal amplifier (sound system)
+2 - Karosserievariante "Avant"
+4 - Leather equipment
xx?xxx: Vehicle configuration
+1 - Seat position in front
+2 - Seat position in the back
+4 - Right steering wheel
xxx?xx: Vehicle configuration
+1 - A park assistance in the back
+2 - Refendruck control system
+4 - Pneumatic cushioning
xxxx?x: Vehicle configuration
+1 - Adaptive Cruise Control (ACC)
+2 - Ambientebeleuchtung
+4 - A park assistance in front
xxxxx?: Land coding
1 - German
2 - English (GB)
3 - English (US)
4 - Spanish
5 - Italian
6 - French
7 - Portuguese
8 - reserves
9 - Chinese
- > channel 001 (mm iv-building list)
Sheeting list for MMI functionality CAR menu.
+00001 - adaptive cruise control (PR-8T4)
+00002 - Ambientenbeleuchtung (PR-QQ1)
+00004 - acoustic parking system in front (PR-7X2)
+00008 - acoustic parking system in the back (PR-7X1/7X2)
+00016 - Tire pressure control system (PR-7K3/7K4/7K5)
+00032 - Pushing/issuing roof (PR-3FE/3FR)
+00064 - adaptive air suspension (PR-1BK)
+00256 - Rain sensor (PR-8N3)
+00512 - one touch MEMORY (PR-4K5/4K6)
+01024 - Seat position in front (PR-3PN)
+02048 - Seat position in the back (PR-5Z1)
+04096 - Multi-function steering wheel (e.g. PR-1XW)
+16384 - Telematics (emergency call system/PR-9ZH/9ZS/9ZV)
- > channel 002 (MMI Anzeigeoptionen)
Indicator option for MMI functionality CAR menu.
?xx: Karosserievariante
0 - Sedan (PR-4F0)
1 - Avant (PR-4F0 K8D)
x?x: Chassis number
0 - Chassis number (VIN) do not indicate
1 - Chassis number (VIN) indicate
xx?: Karosserievariante
0 - Right steering wheel (PR-L0R)
1 - Link steering wheel (PR-L0L)
- > channel 003 (author turn value)
Time interval for the automatic reasoning of MMI Hinweismenues.
- > channel 004 (speed threshold)
Speed, starting from which the functions Car menu is switched off.
- > channel 005 (speed delta)
Delta, starting from that the functions Car menu and training procedure one touch of the MEMORY to be again activated (e.g. speed threshold = 15 km/h, speed delta = 5 km/h - > disconnection with 15 Km/h, activation with 10 km/h).
- > channel 006 (MMI hunting time)
Time interval between switching off and automatic driving of the MMI down.
- > channel 011 (MMI function range)
Additional MMI functions
0 - Log book not available
1 - Log book available (standard)
- > channel 012 (type of telephone)
0 - no telephone/telematics
2 - Mobile phone preparation
4 - Telematics
- > Kanel 064 (brightness search lighting)
Change brightness the operating sector search lighting (changes in the controller are not stored).
- > Kanel 065 (brightness function lighting)
Change brightness the operating sector function lighting (changes in the controller are not stored).
- > Kanel 066 (MMI display)
MMI display in-/-switch off.
- > channel 067 (brightness display lighting)
Change brightness MMI display lighting (changes in the controller are not stored).
- > channel 068 (MMI test pattern)
Test pattern on that MMI display spend.
0 - no test pattern
1 - Red
2 - Green
3 - Blue
4 - White
5 - Black
6- Chessboard (black and white)
7 - Chessboard (inverse)
8 - 64 gray tones (vertical bars)
- > channel 096 (transmitting power)
Reduces the transmitting power of the optical bus by half (changes in the controller are not stored).
- > channel 111 (MMI system RESET)
To activate MMI a RESET accomplished over again coded and/or adapted values.
{electrical system I}
Controller coding
STG 09 (electrical system I) select
?xxxxx: Steering column MEMORY
0 - without steering column MEMORY and/or manual steering column
1 - with steering column MEMORY
x?xxxx: Floor space lighting
0 - Floor space lighting as lamp blocks
1 - Floor space lighting as LED blocks
xx?xxx: Headlight
0 - Halogen headlight without SRA
1 - Halogen headlight with SRA
2 - Bi-xenon-headlight
3 - Bi-xenon-headlight with AFS
xxx?xx: Headlight
0 - without automatic headlight
1 - with automatic headlight with sensor rain/photosensor
xxxx?x: Day headlight
0 - without day headlight
1 - with day headlight not selectable over MMI
2 - with day headlight selectable over MMI
xxxxx?: Land variant
2 - North countries (Finland, Sweden, Norway, Denmark)
3 - THE USA (US)
4 - Canada (CDN)
{electrical system II}
Controller coding
STG 4F (electrical system II) select
x?xxx: Glove compartment unblocking
1 - actively (standard)
xx?xx: Inclination sensor
0 - does not block (PR-7AA)
1 - blocks (PR-7AL/7AN)
xxx?x: Sun roof
0 - does not block (PR-3FA/3FL)
1 - blocks (PR-3FE/3FR)
?xxx?: Engine variant
0xxx3 - 6-Zylinder diesel engine 3.0l (PR-T41/1N3)
1xxx4 - 8-Zylinder petrol engine 4.2l (PR-T79/T8T/1N3)
0xxx4 - Other basic engine (PR-TB3/T14/T15/T44/T45/T61/T9G/TQ0/TA1/1N3)
STG Security ACCESS - > function 16
Before the adjustments to be accomplished to be able ACCESS an appropriate Login must be made by the Security. Logincode: 12151
- > channel 1 (inclination sensor threshold)
Alarm threshold in X - and Y direction (default value: 80)
- > channel 2 (heading for time Handschuhksten)
Activaton time for the glove specialized opening (default value: 100)
- > channel 3 (play protection counter)
Time after that is reduced the play protection counter around 1 (default value: 20)
- > channel 4 (play protection counters)
Threshold for the play protection counter, starting from which a control is prevented (default value: 20)
{parking brake}
Controller coding
STG 53 (parking brake) select
000??xx: Engine variant
01 - 2,0l TDI
02 - 2,5l TDI
03 - 3,0l TDI
04 - 4,0l TDI
05 - 2,7l TDI
10 - 2,0l T FSI
20 - 2,4l MPI
30 - 2,8l FSI
40 - 3,0l MPI
50 - 3,2l FSI
60 - 4,2l MPI
70 - 4,2l FSI
000xx?x: Transmission variant
1 - Transmission ML310
2 - Automat AL420
3 - Multitronic VL300
4 - Multitronic VL380
5 - Transmission ML450
6 - Automat AL600
7 - Transmission ML350
000xxx?: Land variant
1 - Remainder of the world (RDW)
2 - USA/Canada
3 - Japan
Controller basic adjustment
STG basic adjustment - > function 04
Group of measured values of 006 (brakes close)
Group of measured values of 007 (brakes open)
It lasts approx.. 5 seconds, until the brakes are completely opened.
Group of measured values of 010 (functional test)
The brake opens and closes 3 time.
Group of measured values of 020 (angle of inclination sensor calibrate)
After approx.. 2 seconds without movement the value is stored, after approx.. the basic adjustment is terminated 12 seconds.
{combination instrument}
Controller coding
STG 17 (combination instrument) select
???xxx: Extra options and optional extras
+000 - no extra options
+001 - second tank characteristic and/or Quattrocodierung
+002 - without FIS (Fof ahrerinformationssystem)
+004 - Clutch vehicle (no mechanism)
+008 - second pair of tire extent
+016 - Tire pressure control
+032 - Pneumatic cushioning (adaptive air suspension)
+064 - AFS (dyn. LWR with Advanced Frontlighting System)
+128 - ACC (Adaptive Cruse Control)
+256 - 70-Liter tank (only front wheel drive)
xx?xx: Land variant
0 - Germany (DE)
1 - Remainder of the world link steering wheel (RdW)
2 - THE USA (US)
3 - Canada (CDN)
4 - Great Britain (GB)
5 - Japan link steering wheel (JP)
6 - Saudi Arabia (SA)
7 - Australia (OUT)
8 - Remainder of the world right steering wheel (RdW)
9 - Japan right steering wheel (JP)
xxx?x: Belt warning
0 no belt warning
1 Belt warning Europe NCAP (optical durable warning, acoustic warning for 91 seconds actively)
2 Belt warning USA/Canada old
(optical and acoustic warning for 6 seconds)
3 Belt warning USA/Canada NAR again
(optical durable warning, acoustic warning every 30 seconds)
4 Belt warning Europe NCAP (including front seat passengers)
5 Belt warning USA/Canada old (including front seat passengers) (optical and acoustic warning for 6 seconds)
6 Belt warning USA/Canada NAR again (including front seat passengers) (optical durable warning, acoustic warning every 30 seconds)
xxxx?: Lighting options
0 - Pointer and scales OUT (Kl.15 & Kl.58 out)
1 - Pointer, scales OUT (Kl.15 & Kl.58 out)
2 - Pointer OUT, scales (Kl.15 & Kl.58 out)
3 - Pointer and scales (2nd characteristic - Kl.15 & Kl.58 out)
Notes:
- there are in the A6 (4F) 2 different countries groupings in the case of the maintenance interval attitudes to carries comes.
- the maintenance interval channels are to be adapted in the following order: 45>43>42>44>49 and/or. 45>42>43>49>44.
Countries group 1 (flexible wartungsintervall): Germany, Belgium, Denmark, Finland, France, Greece, Great Britain, Ireland, Iceland, Italy, Kanari islands, Luxembourg, the Netherlands, Norway, Malta, Austria, Portugal, Sweden, Switzerland/light stone, Spanien/Andorra, Tschechien, Cyprus
Countries group 2 (firm wartungsintervall): Canada and the USA, Poland, Turkey, New Zealand, Australia, China, GUS (without the Baltic, Ukraine, white Russia), special requirement South America (without Argentina, Brazil, Chile), Romania, Chile, special requirement the Near East (Jordan, Syria, Lebanon), special requirement the middle east (Iraq, Afganistan), special requirement Africa (without north/South Africa), South Africa, special requirement North Africa (Egypt, Algeria, Libya, Morocco, Tunesien), special requirements Brunei, Albania, Macedonia, Argentina, Estland, Litauen, Belarus (white Russia), Bahrain, Kuwait, Qatar, Dubai
- > channel 02 (service interval announcement)
To "00000" puts back enters and the value stores.
- > channel 03 (consumption gauge)
The base value is 100 now can it the whole in 1% steps adjust, the respective maximum values is 85 (%) and/or. 115 (%).
- > channel 09 (odometers)
The values give the distance to in the km counter are later indicated (e.g. 11356 for km conditions of 113.560km).
Before the combination instrument the new km conditions accepted must take place a Login with "13861 ".
- > channel 19 (radio clock)
The adjustment of the synchronisation duration for the radio clock takes place in minutes, to which value 0 does not correspond the condition a radio clock blocked.
Range of values: 0 - 50 minutes
- > channel 29 (tank giver characteristic 2) (only Quattro)
The base value is 128 now can it in 1er steps adjust, this corresponds 1/4 litre. The respective maximum values are 120 and/or. 136. The translation of the tank giver characteristic is made by the whole range.
- > channel 30 (tank giver characteristic 1)
- > channel 31 (wet measuring)
Adjustment of the level of fuel in the tank with first filling at the volume. This value serves for the correction, after first switches on for the ignition corrects the combination instrument the tank giver resistance on the indication of litre angebene in this channel.
- > channel 32 (dead volumes)
Adjustment of the volume not seized by the tank giver. This must take place before the Erstbefuellung in the channel 31.
- > channel 33 (full measuring)
Adjustment of the upper half of the tank giver characteristic, this is stretched and/or shrinks. The base value is 128 and can in 1 ohm steps between 112 and 144 be veriiert. In order to start the correction is as the first adjustment value 65535 to be entered.
- > channel 35 (adjustment of the number of revolutions threshold)
The adjustment value 0 corresponds to an oil pressure warning stopped by the factory, if the oil pressure falls at a number of revolutions of 1500 1/min under 1,2 bar. The adjustment can take place in 250er steps (0 - 1000 ).
0000 - 1000 U/min
0250 - 1750 U/min
0500 - 2000 U/min
0750 - 2250 U/min
1000 - 2500 U/min
- > channel 38 (oil min warning)
Adjustment of the oil min warning with low oil level. Before the attitude a Login with 13861 must take place.
0 - deactivates
1 - activates
- > channel 39 (TOG sensor)
Over this channel festeglegt whether the temperature and oil level giver(TOG) in the combination instrument is blocked. Before the attitude a Login with 13861 must take place.
0 - deactivated (in the combination instrument does not block)
1 - activated (in the combination instrument blocks)
- > channel 40 (driven way STR since last service)
The input of the respective desired value is only in steps from 100 km possible, thus effected also the announcement in the display.
- > channel 41 (time since last service)
The input of the respective desired value is only in steps from days possible, thus effected also the announcement in the display in days.
- > channel 42 (minimum km road performance)
The indication takes place in 100km (150x100=15.000km).
080 - firm wartungsintervall (8,000 km/5,000 miles)
150 - flexible wartungsintervall (15.000km)
- > channel 43 (maximum km road performance)
The indication takes place in 100km (e.g. 150x100=15.000km).
300 - flexible wartungsintervall (30,000 km/19,000 miles)
-> channel 44 (maximum time interval)
The indication takes place in days.
365 - firm wartungsintervall (group of 2 countries)
730 - flexible wartungsintervall (group 1 countries)
- > channel 45 (oil quality)
1 - firm wartungsintervall (group of 2 countries)
2 - flexible wartungsintervall (group 1 countries)
- > channel 46 (total consumption quantity) (only gasoline)
The value indicated in litres represents not actual consumption, but an arithmetic procedure for the service announcement from different engine data and run achievement.
- > channel 47 (soot entry) (only Diesel)
The indicated value represents a reference value, for the service announcement. The indicated value is an arithmetic procedure for the soot portion in the engine oil, related to a distance of 100 km.
- > channel 48 (thermal load) (only Diesel)
The indicated value represents a reference value, for the service announcement. The indicated value is an arithmetic procedure for the thermal load in the engine oil, related to a distance of 100 km.
- > channel 49 (minimum time interval)
The indication of the time takes place in days.
365 - firm wartungsintervall (all group of 2 countries)
365 - flexible wartungsintervall (gasoline engines - group 1 countries)
730 - flexible wartungsintervall (Diesel engines - group 1 countries)
{comfort system}
Controller coding
STG 46 (comfort system) select
+000001 - Standard (always active)
+000002 - 10 Tamperalarme (GB/Irland, PR-B09)
+000004 - Lockcylinder unlocks ZV electrically (PR-7AA/8AU)
+000008 - Selective zentralverriegelung (SPS, PR-4K2/4K7/4K8)
+000016 - Theft alarm system (PR-7AN/7AL)
+000032 - Inclination sensor (PR-7AN/7AL)
+000064 - Interior sensor (PR-7AL)
+000128 - Comfort function over FFB (not PR-B29/B30/B34/B35)
+000256 - Right steering wheel (PR-L0R)
+000512 - Avant (back window break recognition, PR-K8D)
+001024 - Heckrollo (PR-3Y2/3Y5)
+002048 - Honk to acknowledgement DWA (PR-A8U)
+004096 - -SAE tail lamps (the USA, PR-A8U)
+008192 - Light package (PR-QQ1)
+016384 - no SAFE function (PR-A8U)
+065536 - Theft alarm system deceleration time (0 seconds)
+131072 - Equipment Highline (rear lights LED)
+262144 - Sun roof (PR-3FE/3FR)
+524288 - Multi-function equipment (PR-F0X/F4E/F4F/F4G/F4J/F4Q/F4X/F4Z/F5F)
- > channel 01 (Personalisierung key 1)
- > channel 02 (Personalisierung key 2)
- > channel 03 (Personalisierung key 3)
- > channel 04 (Personalisierung key 4)
Default value SPS: 96
Default value ZV: 111
+00001 - Passenger door
+00002 - Door at the rear left
+00004 - Door in the back right
+00008 - Trunk
+00016 - Auto-LOCK
+00032 - Comfort-opens FH front
+00064 - Comfort-opens FH in the rear
+00128 - Sun roof open
+00256 - Heckrollo automatically drive out
+00512 - Dimmwert - interior light = 1%
+01024 - Dimmwert - interior light = 2%
+02048 - Dimmwert - interior light = 4%
+04096 - Dimmwert - interior light = 8%
+08192 - Dimmwert - interior light = 16%
+16384 - Dimmwert - interior light = 32%
+32768 - Dimmwert - interior light = 64%
- > channel 15 (inclination sensor)
Alarm threshold (default value: 200)
200 - 100% = 0,0°
180 - 090% = 0,1°
160 - 080% = 0,2°
140 - 070% = 0,3°
120 - 060% = 0,4°
100 - 050% = 0,5°
- > channel 61 (comfort functions)
+001 - Comfort latches over radio for window lifters
+002 - Comfort-open over radio for window lifters
+004 - Comfort latches over radio for sun roof
+008 - Comfort-open over radio for sun roof
+016 - Comfort latches over FH switch FT for FH
+032 - Comfort-open over FH switches FT for FH
+064 - Comfort latches over FH switch FT for sun roof
+128 - Comfort-open over FH switches FT for sun roof
+256 - Comfort latches over closing aster for window lifters
+512 - Comfort latches over closing aster for sun roof
- > channel 62 (ZV functions)
+1 - ZV to flashing
+2 - ZV on flashing
+4 - Kl. the 87 USA logic
{steering wheel electronics}
Controller coding
STG 16 (steering wheel electronics) select
?xxxxx: Execution
0 - Link steering wheel
1 - Right steering wheel
x?xxxx: Steering column adjustment
0 - no electrical steering column adjustment
1 - with electrical steering column adjustment
xx??xx: Steering wheel execution
00 - Standard steering wheel (no multi-function, no Tiptronic, does not heat)
11 - Sport steering wheel with Tiptronic
20 - Multi-function steering wheel (no Tiptronic at the steering wheel, does not heat)
21 - Multi-function steering wheel with Tiptronic (does not heat)
22 - Multi-function steering wheel heats (no Tiptronic)
23 - Multi-function steering wheel heats with Tiptronic
xxxx?x: Function equipment
0 - no on board computer, no GRA, no ACC
1 - On board computer, no GRA, no ACC
2 - with GRA, no on board computer
3 - with ACC, no on board computer
4 - On board computer, GRA
5 - On board computer, ACC
xxxxx?: Karosserievariante
1 - Sedan
2 - Avant (tail wiper)
{shining width adjustment}
Controller coding
STG 55 (shining width adjustment) select
LWR (standard)
00003 - Steel feather/spring without AFS (PR-8Q3 and 1BA/1BD/1BE/1BR/1BV)
00004 - Steel feather/spring with AFS (PR-8Q3 and 1BK)
LWR with AFS (curve light)
Note: The coding is protected by an Security ACCESS. Security ACCESS code: 02000
00016 - Steel feather/spring (PR-8Q5 and 1BA/1BD/1BE/1BR)
00017 - with pneumatic cushioning (PR-8Q5 and 1BK)
- > channel 20 (show-room-effekt) (only AFS)
0 - activates
1 - deactivates
STG of measured value blocks - > function 08
Group of measured values of 001
Go to basic adjustment
Now the headlights manually adjust.
The rule situation of the headlights "is learned" now by the controller.
{engine electronics}
Controller Security ACCESS
STG 01 (engine electronics) select
ACC Aktivierungscode: 13647
GRA Aktivierungscode: 11463
ACC/GRA Deaktivierungscode: 16167
{tire pressure monitoring}
Controller coding
STG 65 (tire pressure monitoring) select
?xxxxx: System
0 - 1 antenna, 433 MHz (PR-7K7)
1 - 1 antenna, 315 MHz (PR-7K8)
2 - +4 triggers, 433 MHz (PR-7K3)
3 - +4 triggers, 315 MHz (PR-7K4)
4 - at present does not occupy (4 antennas, 433 MHz)
5 - at present does not occupy (4 antennas, 315 MHz)
6 - 4 antennas, Japan (PR-7K5; reduced transmitting power)
x?xxxx: Functions
0 - Remainder of the world (RdW)
1 - Remainder of the world (RdW), fail-safe
2 - Remainder of the world (RdW), specially load
3 - Remainder of the world (RdW), specially load, fail-safe
4 - The USA
5 - The USA, fail-safe
6 - The USA, specially load
7 - The USA, specially load, fail-safe
xx?xxx: Target pressure VA part-load
1 - 1.x bar
2 - 2.x bar
3 - 3.x bar
xxx?xx: Target pressure VA part-load
0 - x.0 bar
1 - x.1 bar
2 - x.2 bar
3 - x.3 bar
4 - x.4 bar
5 - x.5 bar
6 - x.6 bar
7 - x.7 bar
8 - x.8 bar
9 - x.9 bar
xxxx?x: Target pressure hectar part-load
1 - 1.x bar
2 - 2.x bar
3 - 3.x bar
xxxxx?: Target pressure hectar part-load
0 - x.0 bar
1 - x.1 bar
2 - x.2 bar
3 - x.3 bar
4 - x.4 bar
5 - x.5 bar
6 - x.6 bar
7 - x.7 bar
8 - x.8 bar
9 - x.9 bar
{telephone/mobile phone preparation}
STG 77 (telephone) select
- > channel 128 (basic volume audio)
So far no further information.
- > channel 129 (hunting time mobile phone)
From 30 seconds to 30 min in seven intervals.
- > channel 130 (waiting period)
Waiting period reference channel for synchronisation with audio components.
- > channel 131 (microphone sensitivity)
- > channel 133 (Bluetooth)
Activation/deactivation, so far no further information.
- > channel 134 (Bluetooth Freisprechfunktion)
Acquits only with inserted mobile telephone, so far no further information.
- > channel 135 (Bluetooth pin)
- > channel 136 (BEEP Delay value)
Time interval between depressing the key and acknowledgement clay/tone.
{door expensive devices}
Controller coding (in front)
STG 42 (door expensive equipment in front/left) select
STG 52 (door expensive equipment in front/right) select
+000000 - Normal glass (PR-4KC)
+000001 - Tracer for gas cap unblocking (the USA, PR-A8U)
+000002 - Door interior grasp lighting (pre-setting)
+000004 - Damming glass (PR-4KR/4KV)
+000008 - Door door/warning lamps (pre-setting)
+000016 - Right steering wheel (PR-L0R)
+000032 - Top illumination door cowl (Ambientebel., PR-QQ1)
+000064 - Apron lighting (PR-QQ1)
+000128 - Outside mirror with MEMORY (PR-6XF/6XL)
+000256 - Mirror heating (PR-6XD/6XE/6XF/6XJ/6XK/6XL)
+000512 - Switch for support rod (pre-setting)
+001024 - Execution Avant
+002048 - el. Safety device for children rear (PR-4H5)
+004096 - Opening assistance
+008192 - Tightening assistance (PR-GZ2)
+016384 - Keyless entry (Kessy, PR-4F2/4K5/4K7)
+065536 - eFH mechanism run deactivate
+131072 - Injuring vehicle
+262144 - Special protection vehicle
+524288 - Ueberschusskraftbegr. and eFH Automatikl. deactivate
Controller coding (in the back)
STG 62 (door expensive equipment in the back/left) select
STG 72 (door expensive equipment in the back/right) select
+000512 - Switch for support rod (China)
{entrance/starting authorization}
Controller coding
STG 05 (entrance/starting authorization) select
+001 - Standard (always set)
+002 - Mechanism
+004 - Advance key
+008 - Land variant the USA
+016 - Right steering wheel
+032 - Achievement reduction (Japan/South Korea)
+064 - Special vehicle
+128 - Avant
{auxiliary/condition heating}
Steeuergeraet coding
STG 18 (auxiliary/condition heating) select
00?xx: Stop valve for cooling agent -N279
0 - no stop valve -N279 blocks
1 - Stop valve -N279 blocks (standard)
00x?x: Circulation pump -V55
0 - without auxiliary/condition heating (no circulation pump -V55 -)
1 - with auxiliary/condition heating (with circulation pump -V55 -)
00xx?: Undervoltage disconnection
1 - over controller for energy management -J644
2 - over fixed voltage level (adjustment)
- Airbag
- brake electronics
- a park assistance
- parking brake
- comfort system
- level control
- satellite radio
{Airbag}
Controller coding
0 - activates
1 - deactivates
Controller coding
0000?xx: Handwheel
2 - The USA
3 - Australia
Controller coding
xxxxx?: Land coding
1 - German
2 - English (GB)
3 - English (US)
4 - Spanish
5 - Italian
6 - French
7 - Portuguese
8 - reserves
9 - Chinese
0 - Sedan (PR-4F0)
x?x: Chassis number
4 - Telematics
0 - no test pattern
1 - Red
2 - Green
3 - Blue
4 - White
5 - Black
Controller coding
xx?xxx: Headlight
xxx?xx: Headlight
3 - THE USA (US)
4 - Canada (CDN)
Controller coding
xxx?x: Sun roof
{parking brake}
Controller coding
01 - 2,0l TDI
02 - 2,5l TDI
03 - 3,0l TDI
04 - 4,0l TDI
05 - 2,7l TDI
10 - 2,0l T FSI
20 - 2,4l MPI
30 - 2,8l FSI
40 - 3,0l MPI
50 - 3,2l FSI
60 - 4,2l MPI
70 - 4,2l FSI
2 - Automat AL420
6 - Automat AL600
2 - USA/Canada
3 - Japan
Controller coding
xx?xx: Land variant
0 - Germany (DE)
2 - THE USA (US)
3 - Canada (CDN)
7 - Australia (OUT)
xxx?x: Belt warning
0 no belt warning
Notes:
0000 - 1000 U/min
0250 - 1750 U/min
0500 - 2000 U/min
0750 - 2250 U/min
1000 - 2500 U/min
0 - deactivates
1 - activates
{comfort system}
Controller coding
+00008 - Trunk
+00016 - Auto-LOCK
200 - 100% = 0,0°
180 - 090% = 0,1°
160 - 080% = 0,2°
140 - 070% = 0,3°
120 - 060% = 0,4°
100 - 050% = 0,5°
+1 - ZV to flashing
+2 - ZV on flashing
Controller coding
?xxxxx: Execution
1 - Sedan
Controller coding
LWR (standard)
0 - activates
1 - deactivates
Controller coding
?xxxxx: System
x?xxxx: Functions
4 - The USA
1 - 1.x bar
2 - 2.x bar
3 - 3.x bar
0 - x.0 bar
1 - x.1 bar
2 - x.2 bar
3 - x.3 bar
4 - x.4 bar
5 - x.5 bar
6 - x.6 bar
7 - x.7 bar
8 - x.8 bar
9 - x.9 bar
1 - 1.x bar
2 - 2.x bar
3 - 3.x bar
0 - x.0 bar
1 - x.1 bar
2 - x.2 bar
3 - x.3 bar
4 - x.4 bar
5 - x.5 bar
6 - x.6 bar
7 - x.7 bar
8 - x.8 bar
9 - x.9 bar
Controller coding
+002 - Mechanism
+004 - Advance key
+128 - Avant
I see that you are a big fan of the TSB library that I set-up with Dr. Cold. I am glad that you are putting it to good use. If I can find the time I will try to update it. I can't imagine owning a C6 without being able to review the TSBs.
Kevin
The more information the better. I do try to promote the site for you because it answers so many questions that people are asking.
Josh@StatusRacing
VAG-COM Discussion
02-26-2004 07:55 PM
Josh@StatusRacing
04-28-2003 03:06 PM
A6intel
09-12-2002 08:35 PM
