Vag-com and 4 malfunctions!
Hi all,
I recently bougth vag-com and only now had time to install it on my laptop, after I connect it to my car I had 4 malfunctions and since I have no clue yet what is causing this:
(Any one have a clue what is causing this malfunctions?)
Address 07: Control Head Labels: None
Part No SW: 4F0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 5150
Coding: 0000007
Shop #: WSC 00051
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
1 Fault Found:
01319 - Control Module for Distance Control (J428)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 12
Mileage: 77006 km
Time Indication: 0
Date: 2008.07.24
Time: 09:22:17
Address 0E: Media Player 1 Labels: 4E0-910-111.LBL
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H43 0470
1 Fault Found:
02244 - Button in Control Head is Stuck
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 7
Fault Frequency: 10
Reset counter: 16
Mileage: 79410 km
Time Indication: 0
Date: 2008.09.23
Time: 12:29:56
Freeze Frame:
Bin. Bits: 10000000
Address 17: Instruments Labels: 4F0-910-xxx-17.LBL
Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
Component: KOMBIINSTR. M73 H08 0630
Coding: 0065143
Shop #: WSC 00051
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 81270 km
Time Indication: 0
Date: 2008.10.31
Time: 16:09:39
Address 37: Navigation Labels: None
Part No SW: 4E0 910 888 E HW: 4E0 919 887 C
Component: MNS ECE H43 1050
2 Faults Found:
02261 - Media Player; Position 1 (R118)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 10
Reset counter: 8
Mileage: 80509 km
Time Indication: 0
Date: 2008.10.22
Time: 16:37:02
Freeze Frame:
Hex Value: 0x4908
Hex Value: 0xB0E6
Hex Value: 0x1100
Hex Value: 0x6F72
02927 - DVD Read Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 81094 km
Time Indication: 0
Date: 2008.10.28
Time: 22:16:56
Freeze Frame:
Hex Value: 0x4907
Hex Value: 0x8F94
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0000007
Shop #: WSC 00051
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 12
Mileage: 77006 km
Time Indication: 0
Date: 2008.07.24
Time: 09:22:17
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 16
Mileage: 79410 km
Time Indication: 0
Date: 2008.09.23
Time: 12:29:56
Freeze Frame:
Bin. Bits: 10000000
Coding: 0065143
Shop #: WSC 00051
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 81270 km
Time Indication: 0
Date: 2008.10.31
Time: 16:09:39
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 8
Mileage: 80509 km
Time Indication: 0
Date: 2008.10.22
Time: 16:37:02
Freeze Frame:
Hex Value: 0x4908
Hex Value: 0xB0E6
Hex Value: 0x1100
Hex Value: 0x6F72
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 81094 km
Time Indication: 0
Date: 2008.10.28
Time: 22:16:56
Freeze Frame:
Hex Value: 0x4907
Hex Value: 0x8F94
Hex Value: 0x0401
Hex Value: 0x0000
Did you clear them to see if they come back?
The CD error is one I keep getting also but there is nothing wrong with the player. I have an iPod installed and just thought it was that.
I'll do my best since I see you are not in the US and the information is a bit different.
1 Fault Found:
<b>Sounds like your Adaptive Cruise Control sensor (J428) failed on July 24 2008. It is located behind the front bumper. It may just be a loose connector for the sensor.</b>
1 Fault Found:
<b>This looks like you had an intermittent stuck MMI button but that may be clear now. It happened 10 times and last occured on Sept 23 2008.</b>
Coding: 0065143
Shop #: WSC 00051
1 Fault Found:
<b>Intermittent communication issue with the electronic parking brake modue J540 located in the luggage compartment right rear under the tools. Looks like it only happened once on Oct. 31 2008.</b>
2 Faults Found:
<b>The media player in position one (inside glovebox left side) is intermittent faulty. I assume this may be your DVD navigation drive. This happened 10 times last time Oct. 22, 2008. Also the DVD itself had a read error twice, most recently on Oct. 28, 2008.</b>
<b>As Egil A64.2s - S6 said it is best to clear and see what comes back shortly.</b>
1 Fault Found:
1 Fault Found:
Coding: 0065143
Shop #: WSC 00051
1 Fault Found:
2 Faults Found:
Re: I'll do my best since I see you are not in the US and the information is a bit different.
Sorry not to give any more info before, but I dind't cleared them because if I need to go to the audi dealer they will see them, and could have more info about them, or not?
One thing I don't understand is, I dont have adaptative cruise control!! How the hell the car is assuming its installed!
About the stuck Button, it might be true, the MMI sometimes is acting strange, turning on and off, and one time I turned it off at the button and it stoped doing that!
The parking brake doesn't brake at the first time we push the button, happened some times yes
My dvd navigation drive is at the trunk, at the glove box I have cd-changer.
I happened some times my navi didn't worked correctly, but I was thinking it was the nav dvd not working well, it was a backup, and I made another and it happened again some time later, it take so many time to read the dvd when this happen and them show insert nav dvd!
In 4 years, it started doing this only this year!
Now I can ask, could this, at least 3, problems be caused by the MMI firmware update!?
I had the correct cd from other forum (copy), like the other updates before...
That is very strange. Maybe something is wrong with the code identification.
It may warrant a friendly mail to the good folks at Ross-Tech to see fi they have any issues reading codes on the 3.0TDI.
It looks like the stuck button and e-brake are legit problems.
Then the others seem to be saying your CD changer is possibly flaky as well as your backup DVD for the nav.
Sorry, I don't know if the MMI firmware update could casue these problems. Good luck though.
Re: Vag-com and 4 malfunctions!
Went to dealer and 1 problem solved, navigation still not work propely!!
Tried with original DVD and loads imidiatly and says calculating route and them takes 2-5 minutes to show the route!
If not calculating the route, only showing the map, works perfect (some time ago taked some time to load the map, but now its ok)
this time:
Control Module Part Number: 4F0 910 732 S
Component and/or Version: Interfacebox H43 5150
Software Coding: 0000007
Work Shop Code: WSC 00051
Additional Info: 4F0910609 Bedienteil MMIC6H07 0870
Additional Info: Geraet 87199
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 83807 km
Time Indication: 0
Date: 2008.12.18
Time: 09:04:40
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 132
Mileage: 83807 km
Time Indication: 0
Date: 2008.12.19
Time: 12:22:56
Freeze Frame:
Bin. Bits: 001
Control Module Part Number: 4E0 910 888 E
Component and/or Version: MNS ECE H43 1050
Software Coding: 0000000
Work Shop Code: WSC 02335
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:00:56
Freeze Frame:
Hex Value: 0x494E
Hex Value: 0x9EB4
Hex Value: 0x1100
Hex Value: 0x5C2B
02444 - Disk Drive Load / Eject Malfunction
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:05:59
03183 - Unknown Error Code
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:06:14
Freeze Frame:
Hex Value: 0x494B
Hex Value: 0xB896
Hex Value: 0x0000
Hex Value: 0x9999
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.21
Time: 19:47:31
Freeze Frame:
Hex Value: 0x494E
Hex Value: 0x9D8F
Hex Value: 0x0201
Hex Value: 0x0204
this time:
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 83807 km
Time Indication: 0
Date: 2008.12.18
Time: 09:04:40
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 132
Mileage: 83807 km
Time Indication: 0
Date: 2008.12.19
Time: 12:22:56
Freeze Frame:
Bin. Bits: 001
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:00:56
Freeze Frame:
Hex Value: 0x494E
Hex Value: 0x9EB4
Hex Value: 0x1100
Hex Value: 0x5C2B
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:05:59
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.19
Time: 15:06:14
Freeze Frame:
Hex Value: 0x494B
Hex Value: 0xB896
Hex Value: 0x0000
Hex Value: 0x9999
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 133
Mileage: 83812 km
Time Indication: 0
Date: 2008.12.21
Time: 19:47:31
Freeze Frame:
Hex Value: 0x494E
Hex Value: 0x9D8F
Hex Value: 0x0201
Hex Value: 0x0204
powderlvr
01-17-2018 12:43 PM
