Vag-com results=6 faults
I got my vag-com today and here are the results:
I got about six faults. Anyone care to interpret?
VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 805.4 Data version: 20090602 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000
Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283
VIN: WAUDG74F05N114978 License Plate: Mileage: 58300 Repair Order:
Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 67 72 77
VIN: WAUDG74F05N114978 Mileage: 93820km/58297miles
00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door,Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283 Page 2
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0060 Revision: --H15--- Serial number: Coding: 01050106190F0120 Shop #: WSC 02325 785 00200
No fault code found. Readiness: 0000 0000
-------------------------------------------------------------------------------Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 H HW: 09L 927 156 Component: AG6 09L 3.2 FSI USA 0020 Revision: --H01--- Serial number: 4014079 Coding: 0000002 Shop #: WSC 02331 785 00200
-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H03 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020895 Shop #: WSC 02331 785 00200
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283 Page 3
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0160 Revision: 27100401 Serial number: 10600300152154 Coding: 0000015 Shop #: WSC 02323 785 00200
Part No: 4F0 910 131 L Component: FBSAUDIC6 EZS H44 0070
Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H26 0080
Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H44 0060
2 Faults Found: 02764 - Access/Start Authorization Switch (E408) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 66 Mileage: 92889 km Time Indication: 0 Date: 2009.06.04 Time: 12:58:28
00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 118 Mileage: 92889 km Time Indication: 0 Date: 2009.06.07 Time: 14:37:24
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283 Page 4
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 730 E HW: 4E0 035 729 Component: Interfacebox H43 1070 Revision: 00000000 Serial number: 360CK057522528 Coding: 0000003 Shop #: WSC 02335 785 00200
Part No: 4F0 910 609 E Component: Bedienteil MMIC6H09 0060
-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 J Component: KLIMABETAETIGUNGH11 0150 Revision: 00000026 Serial number: 00000030008510 Coding: 0524326 Shop #: WSC 02331 785 00200
-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0013123 Shop #: WSC 02335 785 00200
Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335
Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283 Page 5
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7247630 Shop #: WSC 00000 000 00000
1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 3 Reset counter: 156 Mileage: 93180 km Time Indication: 0 Date: 2009.08.07 Time: 14:08:11
-------------------------------------------------------------------------------Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 B HW: 4E0 035 593 Serial number: AUZ4Z7E10 Shop #: WSC 00000 000 00000
1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 159 Mileage: 82445 km Time Indication: 0 Date: 2008.11.20 Time: 10:43:40
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:52:48283 Page 6
Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 B HW: 4F0 959 655 A Component: 56 AIRBAG AUDI8RH29 0310 Revision: 10H29000 Serial number: 00359D08B9Y6 Coding: 0013622 Shop #: WSC 09222 444 85927
Part No: 4F0 910 339 Component: BF-Gewichtsens. 002 0040
-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90025050840242 Coding: 0002041 Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080
-------------------------------------------------------------------------------Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H10 0630 Revision: 00800000 Serial number: 4R8713U35 Coding: 2113263 Shop #: WSC 09222 444 58773
-------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H10 0060 Revision: 10 Serial number: 1200805330007A Coding: 6CFE73CC1B7904 Shop #: WSC 02325 785 00200
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:53:48283 Page 7
Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082954 Shop #: WSC 02331 785 00200
-------------------------------------------------------------------------------Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 K HW: 4E0 919 887 C Component: MNS US H44 0570 Revision: 00000000 Serial number: 378DP057520282 Shop #: WSC 02331 785 00200
1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 5 Fault Frequency: 71 Reset counter: 0 Mileage: 82446 km Time Indication: 0 Date: 2008.11.20 Time: 11:21:30
Freeze Frame: Bin. Bits: 0100
-------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H11 0040 Revision: 00000000 Serial number: *‰U Coding: 0051947 Shop #: WSC 02327 785 00200
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:53:48283 Page 8
Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H15 0100 Revision: 01000015 Serial number: 01003180700000 Coding: 0423997 Shop #: WSC 02335 785 00200
Part No: 1K0 951 605 C Component: LIN BACKUP HORN H02 1301
-------------------------------------------------------------------------------Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F5 910 223 D HW: 4F5 035 223 E Component: DSP-High C6 H14 0310 Revision: PROD_01 Serial number: 00000000027861 Coding: 0000026 Shop #: WSC 02331 785 00200
-------------------------------------------------------------------------------Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000080858 Coding: 0001114 Shop #: WSC 02323 785 00200
-------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H11 0040 Revision: 00000000 Serial number: **V Coding: 0051947 Shop #: WSC 02327 785 00200
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:53:48283 Page 9
Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0005022 Shop #: WSC 02334 785 00200
-------------------------------------------------------------------------------Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 C HW: 4F0 907 357 C Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02331 785 00200
Part No: 4F0 941 329 A Component: AFS-Modul links H05 0010
Part No: 4F0 941 329 A Component: AFS-Modul rechtsH05 0010
-------------------------------------------------------------------------------Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 F HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0480 Revision: 00000000 Serial number: 394DQ057533047 Coding: 0000002 Shop #: WSC 02331 785 00200
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:53:48283 Page 10
Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H12 0490 Revision: 00000000 Serial number: 00000000011733 Shop #: WSC 09222 444 58721
Part No: 4F0 915 105 C Component: von VA0 1503170775 Coding: 344630393135313035432056413031353033313730373735 Shop #: WSC 00000 384 00290
4 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 3 Mileage: 86493 km Time Indication: 0 Date: 2009.03.12 Time: 00:16:43
02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Mileage: 86493 km Time Indication: 0 Date: 2009.03.12 Time: 00:16:53
02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Mileage: 86493 km Time Indication: 0 Date: 2009.03.12 Time: 00:17:04
02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2
Mileage: 86493 km
VCDS Self-Diagnosis Log Friday,14,August,2009,15:41:53:48283 Page 11
Time Indication: 0 Date: 2009.03.12 Time: 00:17:13
-------------------------------------------------------------------------------Address 62: Door,Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 795 Component: TSG HL H11 0030 Coding: 0051754 Shop #: WSC 02327 785 00200
-------------------------------------------------------------------------------Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 753 S HW: 4E0 035 753 A Component: SDS 3501 US H45 0550 Revision: 00000000 Serial number: 00000503210041 Shop #: WSC 12336 024 394758
-------------------------------------------------------------------------------Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 794 Component: TSG HR H11 0030 Coding: 0051754 Shop #: WSC 02327 785 00200
-------------------------------------------------------------------------------Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 A HW: 4E0 862 335 Component: Handyvorb2 H10 0120 Revision: 00000000 Serial number: 00000007520717 Coding: 0010900 Shop #: WSC 02335 785 00200
End ---------------------------------------------------------------------
Mileage: 86493 km
Those faults are related to a weak or low battery...
You should clear them and then check the individual module(s) [rather than run a complete auto scan] and see if they re–appear.
Since you just bought this used car it means that you should bring the car back to the used car dealer and demand that he correct the issues. It also means that the independent mechanic that you had check out the car before you purchased it did not do a very good job.
The rest of the faults look like they are not a big deal as their fault priorities are high and they are related to the nav and radio.
Just wondering what the battery regulator fault is though.
bballfreak
9
04-14-2019 06:59 PM
lmariorod
10-26-2017 11:39 AM
