Vag-Com Scan
Vag-Com Scan
Ok gentlemen, I just got my cable in the mail and this is what I find...
Saturday,23,March,2013,20:13:13:36781
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 76 77
VIN: x Mileage: 98100km/60956miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 0000000000000000
Shop #: WSC 40181 444 64116
VCID: 2B55D3238A8A9D40A4E
6 Faults Found:
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 130
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:40:59
Freeze Frame:
RPM: 1248 /min
Mass Air / Rev.: 277.9 mg/str
Temperature: 21.0°C
Idle
Absolute Pres.: 627.8 mbar
Speed: 0.0 km/h
008198 - Intake Manifold Flap; Bank 1
P2006 - 006 - Stuck Closed
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:43:10
Freeze Frame:
RPM: 2336 /min
Mass Air / Rev.: 468.7 mg/str
Temperature: 37.5°C
Part Throttle
Voltage: 1.640 V
Speed: 39.0 km/h
008199 - Intake Manifold Flap; Bank 2
P2007 - 006 - Stuck Closed
Freeze Frame:
Fault Priority: 4
Fault Frequency: 18
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:43:10
Freeze Frame:
RPM: 2336 /min
Temperature: 37.5°C
Part Throttle
Voltage: 1.400 V
Speed: 39.0 km/h
012410 - Air Intake System
P307A - 009 - Flow too Low - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 15
Mileage: 96741 km
Time Indication: 0
Date: 2013.03.09
Time: 18:03:09
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 158.1 mg/str
Temperature: 93.0°C
Idle
Voltage: 12.95 V
Speed: 0.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 5
Fault Frequency: 3
Reset counter: 14
Mileage: 96741 km
Time Indication: 0
Date: 2013.03.09
Time: 18:03:09
Freeze Frame:
RPM: 672 /min
Temperature: 93.0°C
Idle
Voltage: 12.95 V
Bin. Bits: 00000010
001109 - EVAP System
P0455 - 009 - Large Leak Detected
Freeze Frame:
Fault Status: 00000100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 98087 km
Time Indication: 0
Date: 2013.03.23
Time: 14:33:05
Freeze Frame:
Lambda: -2.0 %
Temperature: 15.0°C
Temperature: 61.5°C
Speed: 77.0 km/h
Time: 179.2 s
Temperature: 744.0°C
Readiness: 0000 0000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7E3009211
Shop #: WSC 00000 000 00000
VCID: 285F2C2F9B7CB65849C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 138
Mileage: 95895 km
Time Indication: 0
Date: 2013.03.02
Time: 12:10:06
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D08AYLH
Coding: 0013622
Shop #: WSC 08166 444 85866
VCID: 264322179168A0287B0
Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
1 Fault Found:
01213 - Belt Tensioner Igniter; Rear Middle (N198)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 C
Component: MNS US H44 0960
Revision: 00000000 Serial number: 378C2057519898
Shop #: WSC 02331 785 00200
VCID: 2E53DA37B998E868830
1 Fault Found:
03183 - Data Media not Compatible
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 198
Mileage: 97514 km
Time Indication: 0
Date: 2013.03.17
Time: 00:37:15
Freeze Frame:
Hex Value: 0x514A
Hex Value: 0xEBC4
Hex Value: 0x0303
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDB1CDFB04BEA3F0EAA
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 176
Mileage: 97248 km
Time Indication: 0
Date: 2013.03.14
Time: 12:15:42
Freeze Frame:
Voltage: 11.28 V
Count: 244
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: 06.00.54 Serial number: 00067811720506
Coding: 0001206
VCID: E1C9F10B38C68710CE2
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 165
Mileage: 95895 km
Time Indication: 0
Date: 2013.03.02
Time: 12:10:14
End ---------------------------------------------------------------------
From what I found:
1.I know I have a vacuum line I need to replace,
2.looks like I need to clean the throttle body and reset it
3.I have a faulty seatbelt sensor in the rear middle
q1:I do not know what the parking aid fault is. I do know that my parking aid is not working.
q2:What is the Nav fault?
q3:And what is the fault for the digital radio?
Thanks in advance!
Chassis Type: 4F0
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:40:59
Freeze Frame:
RPM: 1248 /min
Temperature: 21.0°C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:43:10
Freeze Frame:
RPM: 2336 /min
Temperature: 37.5°C
Part Throttle
Voltage: 1.640 V
Speed: 39.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 18
Reset counter: 40
Mileage: 95994 km
Time Indication: 0
Date: 2013.03.03
Time: 00:43:10
Freeze Frame:
RPM: 2336 /min
Temperature: 37.5°C
Part Throttle
Voltage: 1.400 V
Speed: 39.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 15
Mileage: 96741 km
Time Indication: 0
Date: 2013.03.09
Time: 18:03:09
Freeze Frame:
RPM: 672 /min
Temperature: 93.0°C
Idle
Voltage: 12.95 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 14
Mileage: 96741 km
Time Indication: 0
Date: 2013.03.09
Time: 18:03:09
Freeze Frame:
RPM: 672 /min
Temperature: 93.0°C
Idle
Voltage: 12.95 V
Bin. Bits: 00000010
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 98087 km
Time Indication: 0
Date: 2013.03.23
Time: 14:33:05
Freeze Frame:
Lambda: -2.0 %
Temperature: 15.0°C
Temperature: 61.5°C
Speed: 77.0 km/h
Time: 179.2 s
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 138
Mileage: 95895 km
Time Indication: 0
Date: 2013.03.02
Time: 12:10:06
Coding: 0013622
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 198
Mileage: 97514 km
Time Indication: 0
Date: 2013.03.17
Time: 00:37:15
Freeze Frame:
Hex Value: 0x514A
Hex Value: 0xEBC4
Hex Value: 0x0303
Revision: C63C0030
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 176
Mileage: 97248 km
Time Indication: 0
Date: 2013.03.14
Time: 12:15:42
Freeze Frame:
Voltage: 11.28 V
Count: 244
Coding: 0001206
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 165
Mileage: 95895 km
Time Indication: 0
Date: 2013.03.02
Time: 12:10:14
From what I found:
Thanks in advance!
I expect you are correct about the vacuum line. The one on the front left side of the engine that operates the intake manifold flaps is a chronic failure point.
I had the center rear airbag sensor code after installing a child seat once but when I reset it it never came back.
The digital radio code is because you don't have a Sirius subscription.
Sorry but I can't help with the Navigation or the Park Assist.
packge33
07-15-2012 12:17 PM
