VAGCOM coding dilema
I always get that "Button Inactive" message every time I press the voice command button on my steering wheel so today I decided to test drive my new VAGCOM. I went to:
[Select]
[46 - Cent. Conv.]
[Coding - 07]
I tried to change from the default which is 0010900 to 0010970 (US English)
It errored out with the message - "Coding rejected, Error 31 Request out of range"
Funny thing is, it accepted the 0010920 code for (English UK) though the button didn't activate still. Does anyone know what I'm doing wrong here?
With that failed, I went on to try activating - opening/ closing windows and sunroof via remote...well here I'm not exactly sure what numbers to enter in the Software coding box - see attached pic. Does anyone know the exact code to punch in?<ul><li><a href="http://pictureposter.audiworld.com/145617/comfort.jpg">link to Vagcom windows, sunroof open/close</a></li></ul>
[Select]
[46 - Cent. Conv.]
[Coding - 07]
AudiWorld Expert
...so just simple math. Sorry, no help on the voice button. Changing to US code worked fine on the B8 S5/A5
Check in VAG COM that your telephone module doesn't have phone voice control coded (voice control must be 0 there if you have the full SDS enabled elsewhere otherwise they apparently clash).
This A5 VAG COM page has some related information, A5 works pretty much the same as A6 in this regard (same components).
Interesting VAG-COM codes for Audi A5
http://www.geocities.com/a6retrofit/articles/a5vagcodes.html
Also check this article that has some notes on coding voice control:
Bluetooth phone prep and speech dialogue system retrofit Audi A6 (4F/C6) Avant MMI High
http://www.geocities.com/a6retrofit/articles/a6phoneprep.html
If you car has only phone voice control (not the full SDS module), then remove any voice coding from cent. conv. and code the voice into telephony module coding instead.<ul><li><a href="http://www.geocities.com/a6retrofit/articles/a5vagcodes.html">http://www.geocities.com/a6retrofit/articles/a5vagcodes.html</a</li></ul>
Audi brand
04-29-2004 12:30 AM
ULuvItBch
09-12-2003 11:56 AM
STEVE2.7T
02-11-2003 06:09 PM
MyKey
03-20-2002 05:30 AM
